| Author |
Message |
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Tue Jun 29, 2010 9:02 am |
i picked up a vitara that is ment to have a blown head gasket.
my question is do they blow gaskets much, warp the heads or should i be looking for a crack in the head and where?
want33s
Joined: Fri Nov 16, 2007 10:30 pm Posts: 8134 Location: Sunshine Coast Qld
 Posted: Tue Jun 29, 2010 9:27 am |
Brett wrote: i picked up a vitara that is ment to have a blown head gasket.
ha ha ha ha...
G16B heads are absolute crap... I went through three before buying a BRAND NEW BARE HEAD .....
Damo
Joined: Sat Jul 22, 2006 11:30 pm Posts: 4661 Location: Brisbane
 Posted: Tue Jun 29, 2010 9:33 am |
Take off the rocker cover and there are some welch plugs under the rocker shaft (3 if I remember correctly). They crack between those welch plugs.
_________________ SJ50.4.LYF
Brett
 Posted: Tue Jun 29, 2010 10:07 am |
Damo wrote: Take off the rocker cover and there are some welch plugs under the rocker shaft (3 if I remember correctly). They crack between those welch plugs.
hopefully is this
ha ha ha ha...
what did it cost you?
i'm hoping to have it done so i can go to stockton next weekend.
appsie
 Posted: Tue Jun 29, 2010 10:54 am |
if the head is cracked then i doubt youll be going anywhere by next weekend.
could be worse,the block could have a slight crack
Brett
 Posted: Tue Jun 29, 2010 10:58 am |
just depends on how quick the postie is if its cracked. swapping heads won't take long.
want33s
 Posted: Tue Jun 29, 2010 10:35 pm |
Bare head was $550...
It's hard to see but there are cracks around the little welsch plug.
This was the 2nd head and the crack is a little more obvious.
JrZook
 Posted: Tue Jun 29, 2010 11:18 pm |
Same head and same issues as the G13BB jimny engine. Have fun setting the tappets
BlueSuzy
 Posted: Wed Jun 30, 2010 12:22 am |
Err.. Mine sounds like a diesel...Tappets?
Brett
 Posted: Mon Jul 05, 2010 7:50 am |
well i finally got the head off this arvo and its cracked so i'm about to see where i can find a new head from.
on a side note the suzuki engineers must hate the mechanics or they are kids with small hands! that was the hardest head i have had to pull off.
