It is currently Sat Oct 31, 2026 12:39 am
Post Posted: Tue Jun 29, 2010 8:38 am
Hey guys another one for you
I havethe 89 wide track hardtop sierra with 1.3 motor been into 2 local shops they reccomended 2 different filters even the book is confusing as they don't list a sierra with 1.3ltr motor.
What is everyone using?
Thanks again
Post Posted: Tue Jun 29, 2010 8:41 am
i am running a z125..
same year model as yours
Post Posted: Tue Jun 29, 2010 8:44 am
Z172 for 1.3 sierra and vits I think (its the biggest), Z125 for 1 litre and swifts, Z418 for later vits and swifts
they all interchange to a point if there is room, I cant fit a 172 on my vit cause the ac is in teh way :)
Post Posted: Tue Jun 29, 2010 8:45 am
Cool thanks for the fast reply, the one on there now i cant find a # so was hoping the 125 seems to be in stock both places.
Post Posted: Tue Jun 29, 2010 8:47 am
royce
is the 172 a lot bigger than the 125? never got told about that 1 :?
Will the 125 be ok on the 1.3?
Post Posted: Tue Jun 29, 2010 8:56 am
yeah a fair bit bigger, i'd track one of them down
Post Posted: Tue Jun 29, 2010 8:59 am
A/C Delco's Ac030 is the same as a Z172..
Post Posted: Tue Jun 29, 2010 9:04 am
Ok i normally use the AC delco on my cars so ill see if i can track down a AC030 thanks
Post Posted: Tue Jun 29, 2010 9:07 am
Thay good filter's, after seeing a ripco filter cut open i will never use one on my car's again..
silverline are worse again... 8O 8O
Post Posted: Tue Jun 29, 2010 11:47 am
How do the AC Delco's compare to the other brands - Fleetguard, Valvoline, Ryco?
2002 SWB GV
Lifted and Locked
Post Posted: Wed Jun 30, 2010 6:55 am
want to go into some more detail there stekky??
what was on the inside??
Post Posted: Wed Jun 30, 2010 8:40 am
1/2 the filter paper than a ryco 8O
Post Posted: Wed Jun 30, 2010 8:42 am
That's a truck brand yes?? Tis all I've ever used em on.
Other 2 are the same quality, delco whip's em both tho..
Vehicle: 4wd
Post Posted: Wed Jun 30, 2010 10:08 am
http://www.allclassifieds.com.au/ac/ac0 ... 318&ss=ACT
Watch out or you'll get sued.
Post Posted: Wed Jun 30, 2010 10:10 am
i am actualy running a GENUINE suzuki one. i bought it off suzishop and it came genuine!
bigest filter u can is genraly good but if u service every 5000km it should be fine!
Post Posted: Thu Jul 01, 2010 12:07 am
Yes Fleetguard is made by Cummins. I think I've found an equivalent to the Z418. Not 100% sure though as I need to confirm.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Jul 01, 2010 6:48 am
Say no more, thay will exceed A/c's spec's..
Post Posted: Fri Jul 02, 2010 3:39 am
I found some info:
J20A oil filter part number: 16510-61A02 oil filter
Ryco equivalent: Z418
Fleetguard equivalent: LF3615 Fleetguard
2002 SWB GV
Lifted and Locked
Users browsing this forum: Google [Bot] and 386 guests
