It is currently Wed Oct 28, 2026 9:29 pm
Vehicle: '85 Sierra LWB Ute, Lkd 33's
Post Posted: Sat Jul 03, 2010 9:41 am
Gonna make it out of ~2mm steel, with weld on brackets (~6mm) onto the tube (going to sleeve in some more tube, heavy wall and plug weld) between the chassis rails.
Cut it with cnc plasma and fold it up 8)
Anyone know the diameter of the haymen-reese hitch pin?
All being well, have some decent snatch points and a shweet bar
'88 Tin Top Sierra, '95 JX Vitara Estate
Go hard,
Post Posted: Sat Jul 03, 2010 10:00 am
I think a tow hitch will bugger your ZU
l
Post Posted: Sat Jul 03, 2010 10:12 am
wasnt planning on a tow hitch, just wanted to use the pin
Go hard,
Post Posted: Sat Jul 03, 2010 10:14 am
Looks good mate....well done 8)
Post Posted: Sat Jul 03, 2010 10:33 am
use 3mm minimum. one hit on the corner and that thing will twist up instantly.
Post Posted: Sat Jul 03, 2010 11:46 am
The hole for the hitch reciever pin is 16mm, the pin is slightly less than 16mm
Post Posted: Sat Jul 03, 2010 11:53 am
where does your number plate go?
Female hitch material is 65mm shs, 6mm wall. The hitch is 51 mm SHS or solid, but you need to be carefull to match the corner radius'.
Post Posted: Sat Jul 03, 2010 12:44 pm
I'm going to make a bracket up off the spare weel.
Go hard,
Post Posted: Sat Jul 03, 2010 12:46 pm
cool. 8)
Post Posted: Sat Jul 03, 2010 12:49 pm
5/8" = 15.875mm
Users browsing this forum: Google [Bot], winchzook and 320 guests
