It is currently Wed Oct 28, 2026 1:23 pm
Post Posted: Tue Jul 06, 2010 12:03 am
so ive just put a new CD player in my 1990 sierra....
wired it up ok and it works good, except that it doesnt store the radio stations
if i have the aecessories on and store it, turn the system off and then back on agian (with the aecessories staying on) it remembers the stations no probs
if i store the stations, turn the radio off and then turn the aecessories off aswell when i turn them back on it hasnt remembered them at all??
i fiddled around with the memory power wire (see pic) disconected it and it cut power to the whole system (so the power/memory wire obiviously works)???
the previous owner must have had a different head unit and for some reson wired a 15 amp fuse near the end of the wire, i left it in the circuite would this have anything to do with it??
does anybody know what the go is?
any help would be hugely apriciated
Post Posted: Tue Jul 06, 2010 12:06 am
Have you got a constant power wire running from the battery? My last one did the same till I wired up one of those...
The LWB From 1993. Poetry in motion :P
Post Posted: Tue Jul 06, 2010 12:12 am
you have to have the constant wired for anything to be remembered same as it wont remeber what song location of song or anything on a cd if you don't do that as well that constant is yellow do that then you will be set.
Post Posted: Tue Jul 06, 2010 12:30 am
Sounds like you have the 'memory' wire hooked to accessories instead of constant power... Find a power feed that is live when key is off and hook it to that. Usually the back of the ignition switch is a good place for constant live.
Post Posted: Tue Jul 06, 2010 1:08 am
im a idoit!! i had the power wires round the wrong way, my bad
thanks heaps
Users browsing this forum: No registered users and 280 guests
