It is currently Wed Jul 29, 2026 11:42 am
Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2
Post Posted: Fri Jul 16, 2010 9:13 pm
What's wrong with them BUZ???? :? :?
From the pic thay look the same a alax's... :P
Except for the tyre's.... :roll:
Post Posted: Fri Jul 16, 2010 9:23 pm
nah they are 0 offset or maybe 5mm, normally what you would put on a vitara
Post Posted: Fri Jul 16, 2010 9:35 pm
Thay look bigger than 0's..
std sierra's -5????
Post Posted: Fri Jul 16, 2010 10:36 pm
http://www.auszookers.com/index.php?nam ... light=15x7
in case it helps =)
Post Posted: Fri Jul 16, 2010 11:33 pm
i just got some 15x7's on my nt on tuesday. was gonna get 15x7 -15 desert rats but couldnt get them in black so ended up getting 15x7 -12 DYNAMIC rims. they stick just outside the guards now by about 1 inch (30x9.5's) and have no scrubbing at all on the springs or chassis anymore so they have done the job well
Post Posted: Sat Jul 17, 2010 1:46 am
I lay a straight edge across my rims, no tyres as yet, and its 4" from the top to the mating surfaces, on a 10".
So the means on the other side, its 6"
Does that therefore mean I have a 1" offset, as 4" + 1" = 5", half the wheel width.
I have read a lot on this, but cannot get my head around it, maybe I have read too much, as there seems to be a lot of contradictory advise out there.
Post Posted: Sat Jul 17, 2010 2:07 am
yep, that is right.
from those measurements the have 4" backspacing (USA terminology) or -25mm offset
Post Posted: Sat Jul 17, 2010 2:13 am
Taa mate, this is where I get confused, some talk of backspace, and others of - or + but obviously its the same in the end.
I remeasured, and from outer lip to outer lip is 11", so I asume add 12.7mm to the offset, so 25 + 12.7 call it 38mm
I just measured the 8" rims on suziblu, (f100 rims) and from what I can tell, these will stick out 55mm further, so that means no spacers, yaaaaa.
Post Posted: Sat Jul 17, 2010 7:42 am
well taht could be all going out the window for me as i might be up/down grading to a mq patrol witha few extra fruits for 3.5
-indebt 4x4 club-
nav 32s n winch cust rear
Vehicle: Ducati Monster
Post Posted: Sat Jul 17, 2010 8:06 am
steknig wrote:
bulldoggy wrote:
So what rim combo do ya recomend for the Body/spring compromise, or will i be cutting the guards?
15x7 at -15
You will need to massage the guard's on the firewall, there is a seam that stick's out, just hammer that flat on the vertical & down on the horizontal..
& fold the wheel arch back a lil to..
stekky would all that still be needed with the 2 inch body & spring lift???
Post Posted: Sat Jul 17, 2010 8:11 am
nice knowing you buzzy :finger:
Post Posted: Sat Jul 17, 2010 8:20 am
Shansh wrote:
steknig wrote:
15x7 at -15
What tyre's??? :roll:
At a guess, yes, a lil bit.. But hitting thing's with hammer's is fun.. :twisted:
Post Posted: Sat Jul 17, 2010 8:25 am
your right mate hitting things with hammers if lots of fun, so are gas axes :)
Post Posted: Sat Jul 17, 2010 8:39 am
doesnt mean im leaving u sweet heart ;)
-indebt 4x4 club-
Post Posted: Sat Jul 17, 2010 2:47 pm
I just bought some 15x8's
Flipped centres, more offset, yada yada.. :D
Not sure of the actual offset value however
Anyway, in easy terms.. 1" of the rim is inside the body (Not including flares)
And 7" is outside
I LOVE IT
Post Posted: Sat Jul 17, 2010 4:06 pm
And 7" is outside
8O hope you like replacing wheel bearings
Trogdor 2 97 Sierra --- sold
zookless atm
Post Posted: Sun Jul 18, 2010 3:15 pm
I don't drive on the road very often
And i've heard from a few different (reliable) people that they've had no wheel bearing issues after running similar offset rims for years
They'll be just fine for what i do
Users browsing this forum: No registered users and 677 guests
