It is currently Thu Oct 29, 2026 4:38 pm
Post Posted: Wed Jul 21, 2010 4:15 am
I have a J20A engine and have found that fluid in the radiator overflow tank is a shade of brown, whilst the fluid in the radiator is still fluoro green. I've replaced the overflow fluid a few times and it still seems to go brown'ish after a week or so.
It's been suggested that rust in the system could be the cause. As the block is alloy and the radiator is aluminium/plastic I'm not sure where it could rust from.
Could it be algae growth in the overflow tank instead?
2002 SWB GV
Lifted and Locked
Vehicle: MY2019 Jimny
Post Posted: Wed Jul 21, 2010 5:10 am
rust in the bottle?
Post Posted: Wed Jul 21, 2010 5:15 am
lump_a_charcoal wrote:
rust in the bottle?
Rust in the cooling system which is then pumped into the overflow bottle.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Jul 21, 2010 5:28 am
Sediment in teh block rises and goes out the overflow
for giggles get a 2l softdrink bottle and fill with clean water, stick it in the radiator filler with the engine warm and idling (dont burn yourself) and watch the crap that floats up
Post Posted: Wed Jul 21, 2010 5:32 am
rust in the bottle?
No I mean maybe there is rust powder in the bottle, which is turning the water brown.
Post Posted: Wed Jul 21, 2010 5:34 am
Is the sediment worth worrying about?
I flushed the radiator fluid about 1 year ago and the problems only really started about 6 months ago.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Jul 21, 2010 5:35 am
rust in the bottle?
Don't think so. I've cleaned out the overflow bottle a few times and put clean water back in just to check.
2002 SWB GV
Lifted and Locked
Post Posted: Wed Jul 21, 2010 6:10 am
i got mud in mine once cos i was submerged and the lid came off the overflow... lol - it was a one off event but took a year or so to get the crap out!
Vehicle: Suzuki Vitara SV620, 2.5turbo
Post Posted: Wed Jul 21, 2010 6:50 am
Just flush it and instead of just putting water in it, Put coolant in it so algae can't grow in there. If it turns brown again than you know something weird is going on. If the water in the radiator is green than your overflow should be green unless you got mud in it ;)
Post Posted: Wed Jul 21, 2010 8:12 am
my J20a will discolour the coolant in radiator overflow bottle over a period of time also...
it's very weird, the coolant in the radiator is hyper colour green like proper coolant but after a while the coolant in the bottle will go brownish.
royce is onto something, the 2lt coke bottle full of water is a good way to pick up the gunk that floats in the system, i have a length of hose & coke bottle to assist in bleeding the air out when doing a coolant change & it will always have floaties in it even after fresh coolant.
Vehicle: '94 suzuki maruti
Post Posted: Wed Jul 21, 2010 10:41 am
same problem here. proper green colour coolant is meant to be (or red, as my case was before i changed over) yet overflow bottle full of brown-green (brown-red) coolant. i just assumed algae or something. never thought of rust... stupidly enough.
Post Posted: Thu Jul 22, 2010 12:11 am
As what's been happening with the other replies, I have green coolant in the rad except it goes green/brown in the over flow.
Seems to be a common problem then.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Jul 22, 2010 12:12 am
So where do the floaties come from, and what the hell is it???
2002 SWB GV
Lifted and Locked
Post Posted: Thu Jul 22, 2010 12:21 am
you still get corrosion, bits flake off the inside of hoses, minerals in the water
the block is cast using sand to form the water jackets, usually this sand is never 100% cleaned out and gradually breaks away from teh remaining clumps, some mid 80's falcons were that bad for it you could pull the welch plugs out and scoop it out and the radiators would be half full of it and so on
Users browsing this forum: Angus Martin and 118 guests
