It is currently Wed Oct 28, 2026 1:06 am
Post Posted: Fri Jul 23, 2010 4:37 am
I have just rang my local repco and suzuki dealer and both want around $350 just for the fuel filter. Does anyone know where to get one any cheaper?
Vehicle: SJ80, SE416
Post Posted: Fri Jul 23, 2010 4:48 am
You could try Suzi Auto Services or Suzisport and see what they quote.
They aren't a cheap filter like Sierras though - the jimny ones are mounted inside the tank.
Post Posted: Fri Jul 23, 2010 4:50 am
how many k's does has ya jimny have on it? they arn't cheap but than again if you only have to change them every 230000km's.
Post Posted: Fri Jul 23, 2010 4:57 am
ha ha yeah almost exactly 230000kms it is getting a shudder every now and again probably once a week I suppose. But goes quickly just doesn's seem to be getting enough fuel.
Post Posted: Fri Jul 23, 2010 5:07 am
Just talked to Suzisport he thinks it isnt the fuel filter and that it is more likely an engine sensor. I have heard of crank angle sensors causing similar issues.
Post Posted: Fri Jul 23, 2010 5:18 am
i have also heard of g13bbs having an issue like this. they have a cam shaft sensor, they dont have a crank sensor i dont think
Post Posted: Fri Jul 23, 2010 7:23 am
99% it will be the camshaft angle sensor. 230000km is a good run from one - many fail well before 100000km. A random shudder is one symptom. Stalling at idle when hot is another.
A blocked fuel filter will give a lean out condition under full power due to falling fuel pressure, and will be present under all identical conditions. Give the car a long, full throttle pull in, say, 3rd gear - if it doesn't start to feel choked or restricted it's unlikely to be fuel filter related.
Post Posted: Fri Jul 23, 2010 10:14 am
unfortunately thats how much they are, and expensive to fit, as stated before they are inside the tank so it needs to come off first.
Post Posted: Fri Jul 23, 2010 10:38 am
How much is a cam shaft angle sensor
Post Posted: Fri Jul 23, 2010 10:49 am
about $175
Post Posted: Fri Jul 23, 2010 10:58 am
a stack cheaper here (less than $100 delivered) Pn 709-1
http://www.nardek.com.au/camcranko2.pdf
Came in a Mitsubishi box (part number J005T23191)
Post Posted: Fri Jul 23, 2010 9:39 pm
Bookmarked that site :)
Users browsing this forum: Google [Bot] and 403 guests
