It is currently Thu Oct 29, 2026 2:21 pm
Post Posted: Fri Jul 23, 2010 11:46 am
Hey fellas i no this has been asked many times and ive been looking at other posts but its making my head spin haha :? . Ive just got a 1997 1.6L efi vitara with all wiring (i think) and i want to do the common swap into a 1.3L sierra. Firstly i want to test it in the vitara but the shitty immobiliser wont let me start it and i dont have the thingy to turn it off :evil: , had a look at bypassing it but all the wires are black! 8O Any ideas? Also wats the easiest way to swap the wiring? Like is there and adaptor or should i tear all the sierra wiring out and replace it with the vitara's :?:
Sorry bout all the reading but any help would be great :D
Post Posted: Fri Jul 23, 2010 12:11 pm
Gday matey last year my misses lost her immobiliser button thingo so we just got a mobile mechanic to call out and bypass it, it cost us about fifty bucks. That will atleast let ya start it
With the wiring i dont have a clue how to do it but if ya send this fella a pm he might wire it up as cash job for ya
http://auszookers.com/index.php?name=Yo ... ofile=1430
Post Posted: Fri Jul 23, 2010 12:30 pm
I had one in my vit. There was a black box under the dash that all the black wiring went into. I just unplugged it. Car works fine :roll:
Post Posted: Fri Jul 23, 2010 12:57 pm
WA's mandatory immobilisers are N/O relays so that doesnt work
to get rid of it just start following the wires from the immobiliser into the loom, when you get a wire thats just tapped into a factory wire, snip it off
when you get to probably 2 or 3 pairs of wires that a factory wire has been cut and the 2 sides joined to a black wire each they are the immobilsed circuits, just cut the black wires off and join the cut wires in the factory loom back together, I reckon youll find at least one of these pairs around the loom from the key
should go fine then
Post Posted: Sat Jul 24, 2010 1:38 am
Cheers guys, ill try unplugging it but something tells me it'll be to easy to be true :roll: haha if that fails ill try rejoining the wires myself which sounds good then if that doesnt work ill call someone out :D
As for the wire transering i'll talk to that guy and see wat he reckons.
Thanks again :D
Users browsing this forum: Google [Bot] and 261 guests
