It is currently Sun Jul 12, 2026 8:51 am
Post Posted: Fri Jul 23, 2010 9:48 am
Just after a 1.6 exhaust manifold, cracked or otherwise to get a flange cut
the same as. Will pick up anywhere in the metro area
doesnt matter if its fwd or 4wd carby or efi.
cheers mick 0437 154 527
Post Posted: Fri Jul 23, 2010 11:41 am
The exhaust ports are different on these two arn't they :?
Post Posted: Fri Jul 23, 2010 12:25 pm
I dunno, just need to borrow one, worst case i will pull of my extractors and
use them to get a flange cut, I thought with every man and his dog doing a baleno conversion there would be some fwd manifolds kicking around.
Post Posted: Fri Jul 23, 2010 12:33 pm
Do you need an EFI 1.6 flange? I have some new ones here. $35 +post. Laser cut 12mm. :D
Post Posted: Fri Jul 23, 2010 2:18 pm
hey man ill double check but im pretty certain we might have the baleno exhaust manifold floating around atm if you just need to borrow it, ill pm you matt's number, he would be the man to speak to about it
Post Posted: Fri Jul 23, 2010 3:32 pm
I chucked mine as it was useless to me. Sorry i didnt keep it 2 years for you.
Post Posted: Sun Jul 25, 2010 9:09 am
cheers fatzook but i need 14mm as its going to be for a turbo manifold
If you can do me at that thickness let me know and i will grab one off you.
bakerboy i will give him a buzz, thanks
Post Posted: Mon Jul 26, 2010 9:54 am
You have pm fatzook
Post Posted: Mon Jul 26, 2010 9:58 am
This one is 12mm, and thats plenty thick enough for a turbo manifold. I should know, cos I've made a few. Standard flange thickness is 8mm.
Post Posted: Mon Jul 26, 2010 10:01 am
You have pm fatzook
Yeah mate I just replied :oops: I get about 20-30 PM's a day, so it doesn't take long for them to get pushed back to page 4 :oops:
Pete
Users browsing this forum: No registered users and 70 guests
