It is currently Wed Oct 28, 2026 7:58 am
Post Posted: Mon Jul 26, 2010 6:29 am
hey fellas, anyone on the gold coast that has done a 16b conversion into a g13a sierra im in need of assistance.
i have a suzuki baleno donor car. if anyone would like to take this job on let us know. i have no idea what im doing when it comes to electrics... and id rather just get someone else to do the work and pay them
Lj81.
Ke20.
Baleno.
Last edited by something_else on Tue Jul 27, 2010 1:12 am, edited 1 time in total.
Post Posted: Mon Jul 26, 2010 8:39 am
so your keeping the ute now???
and you moved back down near the gold coast??
whats your time frame on it?? does it need to be in and running over one weekend or is there a while (like more then a couple of days, maybe a couple of weekend)?
Post Posted: Mon Jul 26, 2010 9:49 am
yeah mate heaps of things have changed..
keeping ute break up with my ex.
and now the baleno gearbox is really getting tired. so its a pretty logical decision.
and for time frame... ill be doin it tough without a car so the sooner the better but a week give or take.. will be fine for me.
regards, ben.
Lj81.
Ke20.
Baleno.
Post Posted: Mon Jul 26, 2010 11:08 am
your going to need quite a few things done.
Below are the main things you need someone else to do apart from physically installing the motor which is actually a fair bit.
1.) Adapter kit (BenT's kit seems the most preferred option)
2.) Extractors (AFAIK vitara manifolds do not clear the engine mount)
3.) Sump and oil pickup modified
4.) Water outlet at the back of the head modified (or blocked off and a jimny intake manifold)
5.) Modified wiring loom
6.) Sorting out the distributor (unless you have the coilpack version of the motor)
What kind of budget do you have?
Post Posted: Tue Jul 27, 2010 1:09 am
$1500
ill buy the adaptor kit from benT
and get the extractors sorted.
also to keep the cost down i should be able to come over and help when needed.
also who ever does it can keep the 1.3. its a go-er
Lj81.
Ke20.
Baleno.
Vehicle: 4wd
Post Posted: Tue Jul 27, 2010 1:41 am
Don't forget you will need either a efi tank or some sort of inline pump system with maybe a surge tank.
Watch out or you'll get sued.
Post Posted: Tue Jul 27, 2010 5:35 am
i was just going to use the baleno tank. the donor car is complete and running.
the ute is a trayback so surely we could fab some brackets up so it can sit under the tray.
Lj81.
Ke20.
Baleno.
Post Posted: Tue Jul 27, 2010 6:08 am
Can you pull the baleno motor and loom from the car?
Is the ute currently running?
Post Posted: Tue Jul 27, 2010 6:52 am
I think id rather let the person doing the conversion handle that. if needed i can though
and no the utes not running do have a car trailer though. its got a spark issue that i frankly cant be stuffed trying to fix anymore. same with the on going carby annoyances.
Lj81.
Ke20.
Baleno.
Post Posted: Tue Jul 27, 2010 7:31 am
Right.
Is it a coil pack or dizzy motor?
Post Posted: Tue Jul 27, 2010 7:39 am
im not sure i do know that it doesnt have the same one as the vitara g16b where are you located?
Lj81.
Ke20.
Baleno.
Post Posted: Tue Jul 27, 2010 7:45 am
I'm in brisbane.
Can you take a pic of the baleno engine?
Post Posted: Tue Jul 27, 2010 7:50 am
sure im just getting off the computer my number is 0457423909 if you send me your email or number ill get back to you tonight. cheers, ben.
Lj81.
Ke20.
Baleno.
Users browsing this forum: No registered users and 261 guests
