It is currently Sun Aug 02, 2026 1:15 am
Post new topic Reply to topic  [ 51 posts ]  Go to page 1, 2  Next
Vehicle: 75 Cruiser
Post Posted: Fri Nov 09, 2007 6:18 pm
yay, so i got a winch today :)
and found some info on OL about how to mount it, so just thought i'd post it here as tech. I would like to mount it on the back so it doesn't stuff up my approach angle. So we'll see how we go.
OL thread: http://www.outerlimits4x4.com/phpBB2/viewtopic.php?t=122396
STIKA wrote:
Formular
19x (1/2 the Drum width)
ie Drum with of 200mm
19 x150 = 2850mm to the first sheeve and the cable will spool on perfect every time
STIKA wrote:
No
you want 1450 mm from the drum to the first lets clal it fair leed or bell on tube then that tube woul run to a fairlead at the front of the car
note the fairlead at the front of the car should be small with no portusions where the cable changes direction
and then this..
nzdarin wrote:
I've been running a mid mounted high for the last couple of years and don't bother using the formula. My first guide was just on 1000mm from the drum and with 50m of 10mm Dynamica, the first and second layer were perfect every time. The rest of the rope would gradually bunch into the midlle of the drum. This did a few things. First no jams, no pressure on the drum.
I'm sure if you had the guide further away it would spool on perfectly all the way to the top layer but I think it works better when it doesn't ie less rope jams with synthetic anyway.
Post Posted: Fri Nov 09, 2007 6:28 pm
I like how the numbers dont add up to his formular
Post Posted: Fri Nov 09, 2007 10:32 pm
Yeah funny.. hehehe
Thanks,
Chris
http://www.nbs4x4club.com
Vehicle: 75 Cruiser
Post Posted: Sun Nov 11, 2007 11:28 pm
mounted the winch on the back. It's not finished yet, so not sure how it'll go with the winding up evenly thing.
Post Posted: Sun Nov 11, 2007 11:52 pm
"It's not finished yet, so not sure how it'll go with the winding up evenly thing."
oooooh difficult one!!..................... this must have been accomplished previously there are heaps of military vehicles with mid mounts.
[quote="royce"]hmm ok havent been there for a year
Vehicle: 75 Cruiser
Post Posted: Mon Nov 12, 2007 12:29 am
yeah, well we made a new front bar and a guide for the rope at the front today. Still have to fit a battery in the back, and smaller fuel tank.
Post Posted: Mon Nov 12, 2007 12:35 am
lookin good stevo. i still think ya should borrow my tires an try that mod truck challenge :wink:
a mate was gonna enter my thing, but it doesnt have a winch, so no go
Post Posted: Mon Nov 12, 2007 12:39 am
Pics???
Post Posted: Mon Nov 12, 2007 4:12 pm
What you need a winch for ?
Event Style:
Rockcrawling for full bodied rigs. No crash and bash BS, just hard technical courses and a few bonuses that will test your teamwork and skill. Courses will be designed so there is no real advantage in larger tyres (no scrably diff hanging pebbles to annoy!!!). The idea is to go wheelin with a good crew of blokes and have a beer after!!! and maybe get a trophy in the process.
Vehicle Specs:
35"min - 40"max tyres
F&R lockers
OEM chassis from centerline of Front diff to centerline of Rear diff - dimensionally unchanged.
Full bonnet, firewall and floorpan width (ute sizing as minimum) minor alterations accecptable. guards preferred.minimum of half doors and window nets/wrist restraints.
Full rollcage as per most comps - and all the usual safety stuff (extinguisher, kill switch etc).
Suspension and steering open.
Winch and sufficient recovery equipment - self recovery!!!
No portal or drop-reduction differentials.
No rear steer.
No rego required.
PM me if you want to clarify these rules any further
um....
Vehicle: 75 Cruiser
Post Posted: Mon Nov 12, 2007 4:31 pm
thanks for the offer ant, but i couldn't run your tyres anyway unless i changed diffs, and that's a whole other bunch of issues, need power steering, maybe more panel clearing etc etc
Post Posted: Mon Nov 12, 2007 7:45 pm
Event Style:
Vehicle Specs:
F&R lockers
No rear steer.
No rego required.
Post Posted: Mon Nov 12, 2007 8:49 pm
opps
Shows how much i can read without my glasses!
um....
Post Posted: Mon Nov 12, 2007 9:19 pm
Looking good Steve! :goodjob:
Thanks,
Chris
Post Posted: Mon Nov 12, 2007 11:29 pm
Beast
[img]http://www.nbs4x4club.com/forum/files/thumbs/
Vehicle: 75 Cruiser
Post Posted: Tue Nov 13, 2007 3:20 pm
if it was going it'd be better :lol:
anyone know if i can stick a big battery in the back, and just wire it up to the front battery... or do i need wierdo isolators and stuff?
Royce, you busy next week after work? :?
Post Posted: Tue Nov 13, 2007 3:53 pm
are you going to make it so you can feed te rope out the back if need be?
and mount a tool box for all the garbage you have to take with a winch?
bang a big battery in the back, get an isolator for between front and back and your done, just a simple isolator will do, its more so that if you are winching heaps with the engine off you dont flatten your start battery as well more than anything, no fancy electronic thingies jsut a simple solenoid type
Vehicle: 75 Cruiser
Post Posted: Tue Nov 13, 2007 4:40 pm
I think the angle of the winch might cause a problem if i wanted to run the rope out the back. not too worried about that though, i think it'd be a rare occassion.
The plan is to have a battery on the left side , petrol tank on the right side, and who knows about a tool/winch box.
where can i get a suitable isolator? supercheap?
Post Posted: Tue Nov 13, 2007 4:43 pm
i have them here Steve
um....
Vehicle: 75 Cruiser
Post Posted: Tue Nov 13, 2007 4:46 pm
how much?
can you bring one tonight?
Post Posted: Tue Nov 13, 2007 4:52 pm
isolator-$20
TJM sticker stuck to it -$200 :)
Vehicle: 75 Cruiser
Post Posted: Tue Nov 13, 2007 4:54 pm
is it a big sticker?
where are they for $20?
Post Posted: Tue Nov 13, 2007 5:17 pm
I know a place :wink:
Post Posted: Tue Nov 13, 2007 6:56 pm
The ones we have here are metal ones that we use for all our mine trucks.
I will bring one tonight for you.
um....
Post Posted: Tue Nov 13, 2007 6:58 pm
get him one of them fancy switches with the 700 terminals on it too :)
Vehicle: 75 Cruiser
Post Posted: Tue Nov 13, 2007 8:23 pm
Thanks Lynda :cheers:
Post Posted: Tue Nov 13, 2007 8:51 pm
Yep have a few spares at home of these :)
They are wayyy cool!
um....
Post Posted: Tue Nov 13, 2007 10:32 pm
earth it to body just run +
make sure ur front earths are nice and big
Vehicle: 75 Cruiser
Post Posted: Mon Nov 19, 2007 11:16 am
got most of it done on the weekend, except for hooking it up to the front battery. Went for a little drive and had to even use it because i got stuck, so we hooked up some jumper leads from back to front and worked well.
It even spooled on pretty good and just started to bunch near the end but still had plenty of room.
We cut the petrol tank in half so it didn't interfere with the rope, and cut the roller fairlead in half to make a smaller slot so it didn't move too much under the car. There is one short bit of tube under the car mounted under a chassis cross member.
Post Posted: Sat Nov 24, 2007 1:48 am
How much fuel can you fit in that tank?!
Post Posted: Sat Nov 24, 2007 1:50 am
Well a sierra tank is 40lt so by cutting it in half I'd guess 20lts :roll: :wink:
Users browsing this forum: fordem, Google [Bot] and 1160 guests
