It is currently Thu Oct 29, 2026 11:34 am
Post Posted: Thu Jul 29, 2010 9:00 am
i have a n/t swb sierra with the 1.6 efi and my heater doesn't work :( the fan blows but no hot air, anyone have this problem and or solved this?
Post Posted: Thu Jul 29, 2010 9:06 am
Are the heater hoses connected?
I did this to mine, it had a heap of crap covering the heater core.
http://www.auszookers.com/index.php?nam ... ght=heater
chop
Post Posted: Thu Jul 29, 2010 9:10 am
Not sure why but the izook link aint working, just went on the site but can access the link. :roll:
Post Posted: Thu Jul 29, 2010 9:11 am
the link on the other thread didn't work.
do you think it could be that simple?
Vehicle: 4wd
Post Posted: Thu Jul 29, 2010 9:26 am
Did they connect the heater hoses when the conversion was done?
Watch out or you'll get sued.
Vehicle: 95 sj70 and 78 lj81
Post Posted: Thu Jul 29, 2010 9:28 am
I had the same problem. After reading what I could I found I had to rip out the entire dash and undo the steering column to get to the heater core. What I found was years of leaf matter built up stopping any airflow through the core. Once I cleared all the stuff out and put it back together it all worked fine. Have attached photos hopefully. In saying that its a big job so make sure all the other bits are working first as said previous and elsewhere
Post Posted: Thu Jul 29, 2010 9:34 am
hmmm yes looks like way to big of a job, i'd be better off buying a beenie and a new hoodie
Post Posted: Thu Jul 29, 2010 10:01 am
It's not hard just takes a while, hardest was getting the electrical plugs back together. Gotta say was worth the effort especially how cold its been. I dont have a back on mine.
Post Posted: Thu Jul 29, 2010 10:13 am
You dont need to take the whole dash out, just drill a hole in the side above the heater core.
Big enough to fit some kind of small vacuum nozzle, loosen up the crap on top of the core with a screwdriver or something pointy but dont dig into the core, a little mirror come in handy to have a squiz.
Then vac the loose stuff out.
And then glue some plastic over the hole.
It was amazing just how good the heater worked after this. :wink:
Post Posted: Thu Jul 29, 2010 10:24 am
hmmm so i guess i could have a play around before i give up all together
Post Posted: Thu Jul 29, 2010 10:38 am
Sierras only put hot air out on the windscreen and feet vents mate ... Try putting it on the windscreen
Vehicle: '94 suzuki maruti
Post Posted: Thu Jul 29, 2010 11:08 am
long shot at best, but it worked for me: check that when you move the temperature knob that the switch under the hood actually moves... in mine, it was rusted shut, but nothing a good spray of WD40 couldnt fix, and been fine since... just worth looking at, only takes 10 seconds
Post Posted: Thu Jul 29, 2010 11:14 am
ah i see well lots of ideas for me to try all but tin tops sound quite involved
Post Posted: Thu Jul 29, 2010 11:19 am
yep thats another good idea, spray all moving parts on the heater controls with wd40 or the likes.
Post Posted: Thu Jul 29, 2010 10:53 pm
I ended up pulling my dash out as well, it was full of leaf litter... then i put some fly screen over the vent
http://auszookers.com/index.php?name=Fo ... t=wet+foot
Still working good for me..
Sam
92 WT, 31" buckshots, half RUF and 6.5:1.. Low and
Vehicle: Suzuki Grand Vitara XL7 2004
Post Posted: Thu Jul 29, 2010 11:24 pm
it's not something silly, my fiancee expect her heater to be blowing hot air the second she turns on her car... you are giving it enough time to warm up ;) hahaha!!!
Abs!!!
Post Posted: Fri Jul 30, 2010 10:59 am
heater is working fine, i just didn't realise it had to be on foot mode to work.. silly me lol.
so thanks for all your advice
Users browsing this forum: Google [Bot], Jezzer and 412 guests
