It is currently Thu Jul 30, 2026 3:59 am
Post Posted: Mon Aug 02, 2010 5:20 am
i had a whinge coming from what i thought was the rear diff, i changed diffs and the whinge is still there.
What could be causing this noise? it only really starts when i hit about 80kms and stop s when i back off.
Post Posted: Mon Aug 02, 2010 5:29 am
could be wheel bearing
Post Posted: Mon Aug 02, 2010 5:48 am
what did the rear bearings look like when you removed the axles?
ball bearings often make a whine when they are on there way out.
Vehicle: LJ20 LJ50
Post Posted: Mon Aug 02, 2010 5:59 am
punch your wife...... that should stop the whingeing
Camels have nice toes
Post Posted: Mon Aug 02, 2010 6:01 am
Or increase it 10 fold lol
Post Posted: Mon Aug 02, 2010 8:13 pm
The noise may not be the diff. Have you had the car on a hoist (or stands) to hear the noise from the source. Quite often noises from the transfer/gearbox can sound like they're coming from the back.
When mine did that it turned out to be the hard casing on the pinion shaft.
 Profile WWW ICQ YIM
Post Posted: Mon Aug 02, 2010 11:38 pm
yeah wheels bearings where my next guess but they didn't look to bad when i pulled axels out,
Post Posted: Tue Aug 03, 2010 12:06 am
Mine was vibrating whining like a bitch.
Turned out to be the rear uni on ther tailshaft. She was seized..
Post Posted: Tue Aug 03, 2010 2:36 am
so best bet would be to take it to a mechanic then i suppose
Post Posted: Tue Aug 03, 2010 2:41 am
if your not able to do bearings your self, yes
Post Posted: Fri Aug 06, 2010 10:35 am
the transfer case looks like its been leaking oil might that be part of the problem? should i check fluid?
Post Posted: Fri Aug 06, 2010 11:10 am
8O Um, yes... 8O
That mud hole you ploughed through will eat out seal's in EVERYTHING, checking oil level's should be part of your wash down..
Post Posted: Fri Aug 06, 2010 11:26 am
oh you saw that didn't you??? it was quite big wasn't it i thought i was going to need a snatch, i don't have a socket or spanner big enough for the transfer case. otherwise i would of.
Users browsing this forum: Google [Bot] and 630 guests
