It is currently Thu Oct 29, 2026 2:09 am
Post Posted: Tue Aug 03, 2010 2:56 am
ok i think i know what the problem is but i thought i would just ask .. every now and a again my low range jumps out of low range i just put the gears in the other day and was going great then it started happping ..i think the cause of the problem would most likey be the transfer bush at " the little rubber ring at bottom of low range gear stick "
when i took my gears out the old one was all broken up so i didnt have a new one so i just put it back togher with out it was all going good because i made it all greasey and sticky with some axel grese ...could not having a tranfer bushing cause the problem of jumping out of gear thanks ...
Post Posted: Tue Aug 03, 2010 2:57 am
it could be that.
Did you make sure all the detent balls went back in the case when re assembling?
Post Posted: Tue Aug 03, 2010 3:05 am
tanshi wrote:
it could be that.
yes i did
Post Posted: Tue Aug 03, 2010 3:15 am
possible that the gear stick rubber is too tight?
Post Posted: Tue Aug 03, 2010 3:16 am
it could also be that the selector ring got put in the wrong way round? i dont think they are simetrical
Post Posted: Tue Aug 03, 2010 3:19 am
hmm but why would it work at all if it was around the wrong way it seems to only be when its underload but then at other times random
Post Posted: Tue Aug 03, 2010 3:46 am
the shifter isn't hitting the tunnel from a bodylift is it?
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Post Posted: Tue Aug 03, 2010 3:51 am
Check detent balls/springs (3 balls 2 springs for the gear lever part).
The bush doesnt hold it in gear it is merely there to help guide the gear lever.
So something else is forcing it to come out of gear. Does the gear shifter touch the body at all? Sometimes the body moves on the mounts causing it to "knock" the lever out. Does it occur more when going down hill then uphill?
255 characters
Post Posted: Tue Aug 03, 2010 4:05 am
up hill but i did cut a small slot for the gear shifter so it wouldnt touch the body
but i would also think me holding the gear in wouldnt work if something was forcing it out when i hold my hand on the gear stick it does not jump out and i do not feel anything trying to push it out
Post Posted: Tue Aug 03, 2010 4:20 am
true... the bush is a 5 sec job... so after doing that you will know for sure whether that was the problem or not.
255 characters
Post Posted: Tue Aug 03, 2010 4:37 am
yerp thanks for the replys guys il keep u posted
Vehicle: MY2019 Jimny
Post Posted: Tue Aug 03, 2010 5:16 am
My boot was forcing it out of gear until I changed it for a softer one.
Vehicle: '92 Sierra
Post Posted: Tue Aug 03, 2010 5:25 am
Is it in highrange or lowrange when it pops out? A dodgey transfer mount could be letting the transfer move enough to knock the gear lever.
Post Posted: Tue Aug 03, 2010 6:04 am
its only low range
Post Posted: Tue Aug 03, 2010 6:37 am
I don't think it would be the ring? I just fitted my. 6.5s and sore that I didn't Even have one.
A know a new one is about $20 because I just got one.
Post Posted: Tue Aug 03, 2010 6:49 am
hmm and u dont have problem at all
Post Posted: Tue Aug 03, 2010 11:13 am
hey belive it or not i got the rubber ring and it fixxed the problem ..i think :)
Post Posted: Tue Aug 03, 2010 9:35 pm
cool... another problem done and dusted then. :goodjob:
255 characters
Post Posted: Wed Aug 04, 2010 1:44 am
good stuff
i never ran the gears without the ring
but it never jumped out with standard gears
Users browsing this forum: No registered users and 674 guests
