| Author |
Message |
orangeshannon
Joined: Sun Jul 11, 2010 12:03 am Posts: 574 Location: Burwood, Victoria
Vehicle: yellow 83 sierra
 Posted: Mon Aug 09, 2010 11:56 pm |
hi i have a 1983 1.0 Suzuki Sierra and the engine has no go in it up hills even on straights. so i would like to know are there any mods i can do to the original engine to give her a bit more go is there any carbys that would it without any mods or are there any other good mods available without changing the engine over because its only just reached 70,000 ks
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Tue Aug 10, 2010 12:24 am |
Its a little old 1,000cc engine, most motor bikes have a bigger engine. Its not really going to make much difference what you do.
Add a bigger carby, and get say 10% more power, but, 10% of fukall is after all, not very much.
Cost will be high for very little gain, IMO go for a bigger donk.
_________________ Bad decisions make good stories.
BlueSuzy
Joined: Sun May 04, 2008 11:30 pm Posts: 9716 Location: NSW
 Posted: Tue Aug 10, 2010 12:53 am |
Id be checking timing, spark, full service. Then go from there.
She is a brick with a 1L..
With my slow 1.1 Corolla i am very understanding of her.. But still quicker than a 1.3 sierra!
royce
Tune it and put quality oil in it, 1 litres are a ripper engine when running right
Fatzook
 Posted: Tue Aug 10, 2010 4:26 am |
royce wrote: Tune it and put quality oil in it, 1 litres are a ripper engine when running right
X a Billionty
orangeshannon
 Posted: Tue Aug 10, 2010 4:44 am |
thanks guys yeah i was just wondering only because im gona be fixing my sierraa up soon with 2 inch lift and some nice muddys for it and i wasnt sure what size muddys to go with the ones im looking at are 29-30 inch i think and i know that the engine is gutless up hills and i knew with bigger wheels it would be worse so i just wanted alittle bit more go in her thats all thanks for your help
Fatzook
 Posted: Tue Aug 10, 2010 5:26 am |
orangeshannon wrote: thanks guys yeah i was just wondering only because im gona be fixing my sierraa up soon with 2 inch lift and some nice muddys for it and i wasnt sure what size muddys to go with the ones im looking at are 29-30 inch i think and i know that the engine is gutless up hills and i knew with bigger wheels it would be worse so i just wanted alittle bit more go in her thats all thanks for your help
You will need to correct your gearing with bigger tyres. More power would help, but not as much as gears.
2stroker
Joined: Sun Sep 07, 2008 11:30 pm Posts: 2689 Location: North Brisbane
 Posted: Tue Aug 10, 2010 6:29 am |
SuziBlu wrote: Its a little old 1,000cc engine, most motor bikes have a bigger engine. Its not really going to make much difference what you do.
Size isn't everything, how big do you think a Formula One engine is ????
Brett
Joined: Tue May 27, 2008 11:30 pm Posts: 1791 Location: Central coast NSW
 Posted: Tue Aug 10, 2010 8:53 am |
turbo's are the cheapest way to gain good power in the long run but a good tune will do heaps for the car
Ben_Sierra
Joined: Wed Sep 30, 2009 11:30 pm Posts: 4472 Location: Perth
 Posted: Tue Aug 10, 2010 8:56 am |
2stroker wrote: SuziBlu wrote: Its a little old 1,000cc engine, most motor bikes have a bigger engine. Its not really going to make much difference what you do.
Cost will be high for very little gain, IMO go for a bigger donk. Size isn't everything, how big do you think a Formula One engine is ????
2.4 litres....
_________________ I want my old sig back
Fatzook
 Posted: Tue Aug 10, 2010 10:18 am |
Brett wrote: turbo's are the cheapest way to gain good power in the long run but a good tune will do heaps for the car
Ordinarily I would say this is true. But most reliable add-on turbo systems will nett a 40-50% gain.
On a 1L sierra motor, this equates to 16kw or less. Which gives a total of 49kw assuming that the 1L still has the factory supplied 33kw. (which it won't)
So at the end of the day you've spent heaps, stressed your probably already tired motor, and only come out of it with the same power as a good 1.3L carby sierra.
WTF is the point?
1600 all the way.
skelaaleks
Joined: Wed Jun 09, 2010 8:31 am Posts: 237 Location: brissy
 Posted: Tue Aug 10, 2010 9:18 pm |
get a suzuki swift motor (not sure what model) but its efi and you can get a turbo model.
AND IT ALL BOLTS UP !!! NO ADAPTOR PLANS OR ENG MOUNTS NEEDED
I WISH I KNEW ABOUT THIS EARLIER
but if you if you wanna keep 1L here is what you should do
Gap plugs
sandblast plugs
make sure your timing is correct
Tune/check carby
set tappets
change oil and filter while you are at it
but to be honest this really wont make much difference in performance.(well not enough anyway)
when it comes down to it your going to need lower gears or more power or both.
TZAR
Joined: Tue Aug 01, 2006 11:30 pm Posts: 3461 Location: licking some windows
Vehicle: LJ20 LJ50
 Posted: Tue Aug 10, 2010 9:34 pm |
skelaaleks wrote: get a suzuki swift motor (not sure what model) but its efi and you can get a turbo model.
but if you if you wanna keep 1L here is what you should do Gap plugs sandblast plugs make sure your timing is correct Tune/check carby set tappets change oil and filter while you are at it
Really???????????
_________________ Camels have nice toes
oozuk
Joined: Sun Aug 16, 2009 11:30 pm Posts: 1452 Location: bethania QLD
 Posted: Tue Aug 10, 2010 10:15 pm |
stop giving bulshit advise
_________________ building a bling zook .......will it ever be finis
jonno_racing
Joined: Wed Apr 15, 2009 11:30 pm Posts: 8164 Location: Tassie
 Posted: Tue Aug 10, 2010 10:26 pm |
oozuk wrote: skelaaleks wrote: get a suzuki swift motor (not sure what model) but its efi and you can get a turbo model.
lol concidering he just asked me if it bolted in...
umm no shit!!! only been done 20 times.
there is no turbo model swift in australia.
_________________ Do cool stuff, Put it on the internet Sierra build, Jimny build https://www.youtube.com/user/redzook1
BlueSuzy
 Posted: Tue Aug 10, 2010 11:04 pm |
Jonno you are king of bullshit.
foolsp33d
Joined: Tue Mar 11, 2008 10:30 pm Posts: 2123 Location: Deep Inside Jamies Mouth
Vehicle: Clown Car..
 Posted: Tue Aug 10, 2010 11:28 pm |
-Lol @ timmay
Got pics of the 1.0 mate!?
I loved TTBB's 1.0 went sooo much better than my 1.3, so im with royce n fatzook.. Go the screamin 1.0!
_________________ Roads... Where we're going we dont need Roads....
Fatzook
 Posted: Wed Aug 11, 2010 12:20 am |
foolsp33d wrote: -Lol @ timmay  Got pics of the 1.0 mate!? I loved TTBB's 1.0 went sooo much better than my 1.3, so im with royce n fatzook.. Go the screamin 1.0!
You didn't read my 3rd post at all did you
DR_JOSH
Joined: Wed Feb 17, 2010 10:30 pm Posts: 178 Location: Adelaide
 Posted: Wed Aug 11, 2010 1:39 am |
Turbo swifts hey,
skelaaleks
 Posted: Wed Aug 11, 2010 11:58 am |
i have seen it with my own eyes guys.
i think the turbo might be an aftermarket kit tho.
Fatzook
 Posted: Wed Aug 11, 2010 12:19 pm |
skelaaleks wrote: i have seen it with my own eyes guys. i think the turbo might be an aftermarket kit tho.
Yes it is. And this can be done to ANY motor given the right amount of knowlege and money.
Jester
Joined: Fri May 08, 2009 11:30 pm Posts: 726 Location: Adelaide
 Posted: Wed Aug 11, 2010 8:50 pm |
well wasnt the suzuki cultus, offered in a factory turbo? havent done my research as to what engine that was
royce
 Posted: Wed Aug 11, 2010 8:54 pm |
there was a turbo 3cyl swift, in what we would cal the GA swift
think it was a G10 base not an F10 though
Fatzook
 Posted: Wed Aug 11, 2010 10:49 pm |
royce wrote: there was a turbo 3cyl swift, in what we would cal the GA swift
And we got that here?
I know of a few people that used to import them as front cuts or long motors, but never actually saw a swift with OEM fitment...
Jester
 Posted: Wed Aug 11, 2010 11:30 pm |
im sure we didnt get em, but that was the only factory fitment i could think of, G10 turbo sounds great my first car was a standard G10 and that would sit on the speed limit no worries, but could also return 4L per 100km too
skelaaleks
 Posted: Tue Aug 24, 2010 6:57 am |
I know a used to know a guy that had 2 swift's one of them had a factory turbo.
he used to work at my petrol station.
SuziBlu
 Posted: Tue Aug 24, 2010 7:10 am |
Fatzook wrote: Brett wrote: turbo's are the cheapest way to gain good power in the long run but a good tune will do heaps for the car Ordinarily I would say this is true. But most reliable add-on turbo systems will nett a 40-50% gain. On a 1L sierra motor, this equates to 16kw or less. Which gives a total of 49kw assuming that the 1L still has the factory supplied 33kw. (which it won't) So at the end of the day you've spent heaps, stressed your probably already tired motor, and only come out of it with the same power as a good 1.3L carby sierra. WTF is the point? 1600 all the way.
I am a bit confused here.
I have seen, on this site, not you Fats, but many others, saying, that they can get 140kph out of a 1l. an that the 1l is far superior to a 1.3l coz it revs very well. I have also read that a 1.3 is far superior to a 1.6l (same deal) coz it revs far better.
SO, I am led to believe, er ?, that a 1l donk is far superior than a 1.6l, because of, or maybe something, revs.
I chase hp at every chance, my 1.3l is a ripper, goes like a cut snake, my mates 1.6l beats me, but from what I have read here, fuk the both of them, bung in a 1l and you will be far better off. ???, even unto a 1.6l with near 3 times the power.
Maybe I have had too many brews.
Gwagensteve
Joined: Thu Feb 26, 2009 10:30 pm Posts: 13007 Location: Melbourne
 Posted: Tue Aug 24, 2010 7:15 am |
1.0 litres are tougher and better designed than the 1.3- they'll take more revs and punishment.
1.3's have more power and torque but are more fragile.
1.6's have more power and torque again but don't rev as hard (longer stroke)
IMHO I quite like the 1.0, I just don't like the tiny clutch and crappy 3.0:1 1st gear in the gearbox.
Good 1.0's are getting hard to find now.
PS the G10 Turbo might bolt in, but that's like saying a 660cc is a bolt in. It is, but it doesn't mean it not a complex conversion for other reasons - wiiring, cooling, fuel system etc. (not to mention legality)
