It is currently Thu Oct 29, 2026 6:40 am
Post Posted: Tue Aug 10, 2010 11:34 am
hi guys so my vitara is making oil, or to be more to the point i am getting fuel in the oil. replaced fuel pump as i thought the diafram might be leaking fuel into the head but its still happening and i think it is running out of the carby when the motor is off.
when i turn it off i can hear a pressure releasing kind of noise straight after the motor stops. so i pulled the fuel feed line off the fuel pump and let it run dry and the noise didnt happen.
is there a fuel cutoff solenoid or something that may be jamming? its a 92 standard carb model. thanks in advance boys.
Post Posted: Tue Aug 10, 2010 12:30 pm
There is a idle stop solenoid, but I can't see that doing what you have described..
How's your tank return???
Post Posted: Wed Aug 11, 2010 8:20 am
hmmm haven't checked... you recon if it is blocked the pressure may force fuel into the intake manifold when i turn it off?
my sierra has developed carb problems also, not having a good run, it will idel for about 3 seconds then starve and die. if i pump the accel it will rev up but then it starves and dies, the only way to actually drive it is to constantly pump the accel down, its as if it is using that bit of fuel thats pumped in then starves and the next pump puts some more in too keep it going etc... recon its on the idel screw side of things? purhaps i should buy your webber and just bolt that on...
Post Posted: Wed Aug 11, 2010 8:42 am
:? Who are you talking to?? :?
Post Posted: Thu Aug 12, 2010 9:39 am
you steknig... sorry i thought u had a carb for sale in the for sale section...
Post Posted: Thu Aug 12, 2010 10:15 am
:P That's me!!!! :P
No I don't.. How's your return line??
Charcoal canister's not full of water is it??
Post Posted: Thu Aug 12, 2010 10:30 am
:P That's me!!!! :P
x 2 i was just about to type that... this is the same car that took a swim the other week!
Users browsing this forum: No registered users and 327 guests
