im having a slight problem finding out what type of seatbelts are in a 1985 suzuki sierra 1l
the car came with retractable seatbelts that werent mounted propery and the car comes with no proper mounting points for retractable seatbelts.
so did this year model of the sierra come with non retractable seat belts? if so does anyone know were i could find some?
Joined: Wed May 21, 2008 11:30 pm Posts: 4972 Location: Dandenong .Vic
Posted: Sat Aug 14, 2010 12:46 am
if there is a removable pannel in the bottom of the B pillar then you can fit late model retractable belts. If ther is not then you can use the static belts. Most decent auto parts places shoould be able to order you inthe correct belt. There are also a few online places that you can buy new ones from.
Posted: Sat Aug 14, 2010 2:27 am
It wouldnt of come with retractable belts from factory
It is possible to get Klippan retractable belts that will fit, they bolt to the factory bottom mounting point and are designed to face the right way so the intertia part still works, you have to be careful they will clear the seats if you have different ones or have them a long way back
Users browsing this forum: Google [Bot] and 326 guests
