It is currently Wed Oct 28, 2026 6:35 pm
Post Posted: Sun Aug 15, 2010 8:12 am
hay guys got some wt diffs to put in my nt just wanting to know will the rear drum braeks change over?.
chees joe
Vehicle: MY2019 Jimny
Post Posted: Sun Aug 15, 2010 8:15 am
You talking about the handbrake?
Post Posted: Sun Aug 15, 2010 8:17 am
To retain your transfer h/brake??
The rear's can be swapped over, but you'll have to change the backing plate's, meaning new wheel bearing's.
If you run the w/t rear's with out the h/bake attached, the self adjusted won't work properly..
I personally prefer the transfer h/bake to w/t's..
Post Posted: Sun Aug 15, 2010 8:45 am
yes thank steknig was going to change the wheel bearings any way. the wt backing plates are all bent and dinted. and was going to keep the transfer hand brake
Post Posted: Sun Aug 15, 2010 8:52 am
just make sure the bearing's are w/t one's, that have a spacer on em..
brake's are fine to change over, that the way i do it.. :P
Post Posted: Sun Aug 15, 2010 9:09 am
ok thanks
Users browsing this forum: No registered users and 301 guests
