It is currently Thu May 07, 2026 5:18 am
Post Posted: Thu Aug 19, 2010 6:46 am
Put a 2nd hand engine in my zook on the weekend. Got it all hooked up, cranked it over and it started up and ran beautifully.....for about 1 minute. Then there was a snap and the engine stopped dead. :?
Turned out it had stripped the teeth on the timing belt, which effectively stopped the engine. After some inspection I realised that I couldnt turn the camshaft with my standard ratchet. However, if I use a breaker bar the camshaft does turn with the extra leverage.
My question is, how easy should the camshaft turn?
Since my camshaft is hard to turn, can I assume it has seized. If so, why would this have happened after only about 1-2 minutes running? and what will need replacing? :roll:
This engine is starting to seriously shit me so any assistance you guys can provide is appreciated.
Member of C.O.R 4x4
Post Posted: Thu Aug 19, 2010 6:50 am
The cam won't be easy to turn, it should of rolled over lobe's, so hard then spin out of you hand..
Fit new belt with all mark in line & start it..
Post Posted: Thu Aug 19, 2010 6:51 am
If the cam shaft was siezed, I doubt you could turn it. But there should be some resistance though.
If the cam is dead, the head is dead. The cam usually ruins the journal it runs in when they seize.
Take the tapet cover off and inspect the top end.
Post Posted: Thu Aug 19, 2010 7:00 am
I've taken the tappet cover off and I cant see any missing bolts. None of the rocker arms are busted as far as I can tell. And theres still plenty of oil hanging round, so it wasn't running without oil supply.
I guess I'll just wack a new belt on, stand back and hope for the best :? . I'll do it tomorrow though, its bloody cold outside atm :lol:
Member of C.O.R 4x4
Vehicle: Clown Car..
Post Posted: Thu Aug 19, 2010 7:49 am
while the rocker cover is of crack n retorque the cam bolts.... check the oil pickup IS actually working.. I learnt the hard way to with the 1.0 two belts in as many days.. :(
fixed but soon after the car went mia.. :evil:
Post Posted: Thu Aug 19, 2010 10:16 am
How can I check the oil pickup is working?
Member of C.O.R 4x4
Post Posted: Thu Aug 19, 2010 10:18 am
Oil pressure guage? :?
Post Posted: Thu Aug 19, 2010 10:19 am
10 bucks...........heads dead.
you will get fresh oil comming up into the head when you crank it over.
Post Posted: Thu Aug 19, 2010 11:54 pm
How many k's on the engine?
How long was it sitting around for?
PooR GeofF :cry:
Post Posted: Fri Aug 20, 2010 7:59 am
Dunno k's. Approx 130'000 if the bloke the previous owner bought it off was telling the truth. The engine came out of a running car and was only sitting for about 2 months.
I put a spare timing belt on it thisarvo but I noticed that its a little loose. The tensioner is at the max of its adjustment and the belt is still easily deflected inwards, not tight like I would expect it to be :? :?:
Cranked it over but it backfired a bit and wouldnt start, so I suspect I have the timing 180 degrees out (even though I followed the haynes manual directions with the timing marks etc :roll: ) Too fricken cold at the moment so I'll check the dizzy alignment tomorrow.
Member of C.O.R 4x4
Post Posted: Sat Aug 21, 2010 2:46 am
Ok, here it goes.
Put a new timing belt on it, cranked it over for a while with the plugs out to build up some oil pressure. I could see the oil being pumped up onto the camshaft so seemed to me to be in order.
Plugs went back in and I started it up. Ran fine for about 10 seconds then went real rough and seized, stopped instantly.
I've pulled timing belt off again (it was still good) and the camshaft appears to be seized. I can not physically turn it.
Why the hell would a camshaft seize after 10 seconds :?: :?
I am at a complete loss since there was oil so I dont see how it could have seized due to lack of lubrication.
Member of C.O.R 4x4
Post Posted: Sat Aug 21, 2010 3:36 am
I now agree with joe..
it was worth a try tho..
Post Posted: Sat Aug 21, 2010 5:13 am
Have you had the sump off and looked at the oil pickup??
http://auszookers.com/index.php?name=Fo ... sc&start=0
Look on both pages of that, goes into a little more detail of exactly what I went through, easier than re-typing it all here. also loosen the camshaft, lube with engine assembly paste and re-torque.
How confident are you that the timing was set perfectly?
Post Posted: Sat Aug 21, 2010 5:16 am
zooker wrote:
Ok, here it goes.
I also had "some oil" being pumped up to the head. remove the spark and the oil sender if it is only trickling out while being cranked over your not getting enough oil. If it's shooting across your engine bay after you have cleaned your oil pickup then money is on the head is dead.
Post Posted: Sat Aug 21, 2010 5:56 am
Shakes - Thanks for your advice. That is almost exactly what happened to me.
I've checked my oil pickup and it is still spotless because I cleaned it before I put this engine in the car. I did notice that the cam gear locating pin hole is slightly ovalled, though not as extreme as yours was. When I was cranking the engine I could see the oil being squirted up enough to coat the cam, but it wasnt like it was shooting across the engine bay.
Was your engine repairable after seizing or was a whole new head needed?
Member of C.O.R 4x4
Post Posted: Sat Aug 21, 2010 6:06 am
It shoots out the oil sender in the side of the block, only a trickle into the head/cam guides.
Mine seem's to be repairable (only ran it for 15-20 mins afterwards havent driven it)
loosen the cam off, lube it all up and re-tighten. Turn by hand a heap of full rotations, if it tightens up then remove your head and take it to get reco'd ($400ish for a full go by the quotes I got) and someone here had a cam regrind specs that seemed to be worth doing to.
Post Posted: Sat Aug 21, 2010 7:21 am
Brand new heads can be had for around the $500 mark
Post Posted: Sat Aug 21, 2010 10:27 am
Bare head? or complete? From suzuki themselves or from a repo joint?
The $400 was for new valves and seals, quick tidy up, pressure test, check cam and journals for true, machine all 3 surfaces and be a bolt on affair.
Post Posted: Sat Aug 21, 2010 9:43 pm
not sure if there still on there but seen new head complete on ebay for around $400-$500 the other week
Vehicle: 4wd
Post Posted: Mon Aug 23, 2010 10:53 am
You should of bought my motor. It was tight.
Sucks as hardly any spares pop up here in canb/qbn.
I tried flynns wreckers the other week and they had nothing.
Watch out or you'll get sued.
Post Posted: Mon Aug 23, 2010 11:14 am
PM sent :P
Users browsing this forum: Google [Bot] and 33 guests
