Hey guys,
Im currently starting a new project front diff housing, that will involve rotating the diff pumpkin.
I want too increase caster, lift pinion angle, plate under shock mounts/pickups, diff armor, etc etc etc while at it.
At present my caster angle is set at 4deg
A mate who's the foreman at Hammand 4x4 recommended around 8deg, he thats what they run on 4"+ lifted Jeep Wranglers.
Part of the reason for this is a continuing problem with caster wobble, at present it only appears lightly occasionally (fitted 9stage adj TuffDog steering damper), the car has been lifted 90mm rear and 110+ front but has only done less than 9000km's and very very little off road work, I have checked kingpins/bearings, all tie rod ends and everything is tight as a nun.
So TECH HEADS preferably, thoughts on a good caster angle, what would be too much caster?
Kyzer
