It is currently Wed Jul 29, 2026 4:42 pm
Post Posted: Sun Aug 22, 2010 11:29 am
ok I know this topic is a bit worn out..but!is it possible to put 1l t/case gears(non switch type) into a 1.3l case????
Also what ratio do the 1L cases come in.....
Coily GTI Turbo...thats right its a coily!!
Vehicle: Clown Car..
Post Posted: Sun Aug 22, 2010 11:40 am
http://www.auszookers.com/index.php?nam ... pic&t=7347
http://www.auszookers.com/index.php?nam ... 0&start=30
Post Posted: Sun Aug 22, 2010 11:53 am
thanks,second link doesn't work...doesn't quite answer the question....
Post Posted: Sun Aug 22, 2010 12:26 pm
second link is search result to ''1.0 transfer ratio''
whats the question? what is a 1.0 ratio?
The Type 1 t/case ratios are: Hi: 1.590, Lo: 2.558
Type 2/3 1.0 t/case: Hi: 1.580, Lo: 2.511
1.3 NT + WT: Hi: 1.409, Lo: 2.268
or this one?
Highway-Star wrote:
aarrhhh. So with that massive "dome" on the counter shaft the early 1.0L type 1 case must run bearings on the end of the shaft, not needle rollers inside the counter cogs like the LJ and later Sierra cases do. Would this be correct?
joeblow wrote:
yes 303....the bottom one with the large hemoroid is the ones that are no good for sierra 1.3 flanges, light or no light.
so depending what case your 1.0 is will be the will or wont it fit into a standard 1.3 case.. why you would want to put 1.0 gears into a 1.3 case idk.. :windowface:
Post Posted: Mon Aug 23, 2010 11:56 am
yea ok cheers...because its easy to get a 1.3 case with a switch and a 1l case with out one...the 1l ratios are lower than 1.3 correct?
Post Posted: Mon Aug 23, 2010 1:35 pm
The gears from a "1.0lt case without switch" (Type 1) will not fit into a 1.3lt case, they are a completely different design and no parts interchange. A "1.0lt case with switch" (Type2/3) is the same design as a 1.3 case and parts such as the gears, flanges and handbrake will interchange. All of the aftermarket reduction gearsets are for the "With light switch or 1.3 style" case.
As for the Ratios, Foolspeed has answered that for you already:
Post Posted: Tue Aug 24, 2010 1:10 am
Vehicle: '94 suzuki maruti
Post Posted: Tue Aug 24, 2010 2:52 am
foolsp33d wrote:
:lol: :lol: :lol:
Users browsing this forum: No registered users and 682 guests
