It is currently Thu Oct 29, 2026 3:38 am
Post Posted: Mon Aug 30, 2010 5:10 am
even when its set to free my front right hubs been engaged for i dont know how long and caused some damaged to my seals on long drives.
i had a look at it, its missing a spring that pulls/pushes the locking nut in and out (not sure on terminology)
is it easyer to replace the whole lot or find parts and fixit myself
Post Posted: Mon Aug 30, 2010 5:45 am
get a 2nd hand one, keep you's for spare part's..
Post Posted: Mon Aug 30, 2010 6:42 am
is there a cheap way of doing this fromm what i see its gonna cost a bit
Post Posted: Mon Aug 30, 2010 6:49 am
If ya can't afford to fix it then don't drive it. Cheap will not work out cheap just means you pay twice in the end.
Steve W
Post Posted: Mon Aug 30, 2010 6:56 am
I'll sell you one for $50 delivered with bolts
Post Posted: Mon Aug 30, 2010 7:01 am
yea this is true
ok in that case what hub would you's recomend, the stock replacement
sorry for all the Questions first time iv done these
i did look at older post but didn't say if i could get just parts
Post Posted: Mon Aug 30, 2010 7:11 am
with your lack of knowledge I would reccomend get a complete set up that all you have to do is bolt it on If you get a spring it needs to be fitted correctly, JMO
Steve W
Post Posted: Mon Aug 30, 2010 9:56 am
i have no proplem taking stuff apart or fitting them thats the easy stuff
all i wonted to know is if its better to fully replace or fix the current, also recomendations on certain types.
by the looks of things its fully replace.
in response to 11_elv, thanks but id rather go local as i need it pretty quick, iv found a suzi wreckers in perth that can suplly good condition onse same price
Post Posted: Mon Aug 30, 2010 10:01 am
Grab one from the wrecker, the hub's are plenty strong enough it's just the spring's that let em down, but that could be put down to lack of maintenance..
& to my knowledge you can't buy just the spring..
Post Posted: Mon Aug 30, 2010 10:12 am
ok sounds good
seems like the car waits till on day for it all to just let go
Users browsing this forum: No registered users and 311 guests
