| Author |
Message |
MR1JZ
Joined: Fri Feb 12, 2010 10:30 pm Posts: 337 Location: Radelaide
 Posted: Tue Aug 24, 2010 9:55 pm |
Guys,
Sometimes after I turn right my rear diff makes a snapping sound and the rear end of the car gets thrown all over the road...it only used to do it occasionally now it has started to become more frequent...any ideas as to what might cause this? When I did the rear bearings the axels looked to be in good condition...could it be the backlash is not set properly in the rear diff?
Im thinking of ripping it out this saturday when I do my front one for a look but I dont know what I should be looking at to be honest
discuss
_________________ 95 W/T - Got a few bits
shep
Joined: Thu Mar 29, 2007 11:30 pm Posts: 14498 Location: Here there everywhere
 Posted: Tue Aug 24, 2010 9:58 pm |
probably needs re shiming.
_________________ JEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEPJEEP
PJ.zook
Joined: Sat Oct 24, 2009 10:30 pm Posts: 845 Location: Melbourne
 Posted: Tue Aug 24, 2010 9:59 pm |
I dont think backlash would make a difference. If backlash was real bad your diff would be making noise and prob getting hot.
Has your driving style changed? New tyres? Is one tyre worn more than the other? Rotated tyres recently?
MR1JZ
 Posted: Tue Aug 24, 2010 10:00 pm |
well that would make sense...is it a difficult job for a diff shop?
if they need reshimming would they make horrible twanging noises like that?
ive got to take my front in there to have it installed next week so I might as well get the rear done at the same time
jdk81
Joined: Sat Jul 18, 2009 11:30 pm Posts: 2372 Location: Ballarat, VIC
 Posted: Tue Aug 24, 2010 10:08 pm |
Check your tyre pressures too.
My locker was acting funny, was due to one tyre having lost a little air.
MR1JZ
 Posted: Tue Aug 24, 2010 10:18 pm |
PJ.zook wrote: I dont think backlash would make a difference. If backlash was real bad your diff would be making noise and prob getting hot. Has your driving style changed? New tyres? Is one tyre worn more than the other? Rotated tyres recently?
driving style hasnt changed...tyres are all good on the pressure and wear fronts as they are nearly brand new
MR1JZ
 Posted: Wed Aug 25, 2010 2:23 am |
after doing some more reading im considering not putting this thing back in the rear...anyone got a spare W/T open centre with factory CW&P they want to sell me?
I wouldnt mind doing a welded diff instead!
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Wed Aug 25, 2010 2:29 am |
MR1JZ wrote: after doing some more reading im considering not putting this thing back in the rear...anyone got a spare W/T open centre with factory CW&P they want to sell me?
good idea.
_________________ builder of custom road legal zooks......and stuff.
MR1JZ
 Posted: Wed Aug 25, 2010 2:37 am |
Should I not bother fitting the front one?
Should I just weld that too?
v6zookie
Joined: Sun Aug 30, 2009 11:30 pm Posts: 35 Location: newcastle
 Posted: Wed Aug 25, 2010 3:05 am |
the shimms which are on the drive gears whear down and need to be re shimmed. It onely takes a few thow and it starts to let go at all the rong times. Its not a hard job just time consuming.it took me a few goes at it to get it right but once you figer out the right set of shimms it is problum solved.and well worth knowing how it works
MR1JZ
 Posted: Wed Aug 25, 2010 3:20 am |
Thanks mate...where can you get the shims from?
lump_a_charcoal
Joined: Wed Feb 28, 2007 10:30 pm Posts: 4454 Location: Botany, NSW
Vehicle: MY2019 Jimny
 Posted: Wed Aug 25, 2010 7:39 am |
The reason I don't have a lockright anymore is for the reasons you described above. Every thing I did to make it behave failed, so it got replaced with an air locker. Best upgrade ever.
PJ.zook
 Posted: Wed Aug 25, 2010 1:15 pm |
Ive got lockrights front and rear and they both work great, dont know what you guys are or arent doing to yours!
Fatzook
 Posted: Wed Aug 25, 2010 1:20 pm |
PJ.zook wrote: Ive got lockrights front and rear and they both work great, dont know what you guys are or arent doing to yours!
All Lock wrongs "work". Its just that most are apparently "set up wrong" and sound like you have a bucket full of gravel in your diff. Not to mention the constant and unpredictable ratching through corners when on the road.
In this order.
Airlocker
Welded
Open
LockRight.
atari4x4
 Posted: Wed Aug 25, 2010 1:32 pm |
Fatzook wrote: PJ.zook wrote: Ive got lockrights front and rear and they both work great, dont know what you guys are or arent doing to yours! All Lock wrongs "work". Its just that most are apparently "set up wrong" and sound like you have a bucket full of gravel in your diff. Not to mention the constant and unpredictable ratching through corners when on the road. In this order. Airlocker herpesWelded genital herpesOpen aidsLockRight.
fixered it
Zook_Fan
Joined: Thu Mar 13, 2008 10:30 pm Posts: 4531 Location: Toowoomba
 Posted: Wed Aug 25, 2010 1:35 pm |
atari4x4 wrote: Fatzook wrote: PJ.zook wrote: Ive got lockrights front and rear and they both work great, dont know what you guys are or arent doing to yours! All Lock wrongs "work". Its just that most are apparently "set up wrong" and sound like you have a bucket full of gravel in your diff. Not to mention the constant and unpredictable ratching through corners when on the road. In this order. Airlocker herpesWelded genital herpesOpen aidsLockRight. fixered it
huh that tells us a lot about atari, he would rather have both herpes and genital herpes than drive a stock vehicle
atari4x4
 Posted: Wed Aug 25, 2010 1:42 pm |
haha, that's very true.... considering i've never owned a vehicle that's stayed stock, although my airlocker is being gayer than aids ATM.
lump_a_charcoal
 Posted: Wed Aug 25, 2010 6:39 pm |
Zook_Fan wrote: atari4x4 wrote: Fatzook wrote: PJ.zook wrote: Ive got lockrights front and rear and they both work great, dont know what you guys are or arent doing to yours! All Lock wrongs "work". Its just that most are apparently "set up wrong" and sound like you have a bucket full of gravel in your diff. Not to mention the constant and unpredictable ratching through corners when on the road. In this order. Airlocker herpesWelded genitalsOpen aidsLockRight. fixered it  huh that tells us a lot about atari, he would rather have both herpes and genital herpes than drive a stock vehicle
I fixed it for him.
ajsr
Joined: Sun Dec 28, 2008 10:30 pm Posts: 3712 Location: melb
 Posted: Wed Aug 25, 2010 8:10 pm |
Fatzook wrote: PJ.zook wrote: Ive got lockrights front and rear and they both work great, dont know what you guys are or arent doing to yours! All Lock wrongs "work". Its just that most are apparently "set up wrong" and sound like you have a bucket full of gravel in your diff. Not to mention the constant and unpredictable ratching through corners when on the road. In this order. Airlocker Welded Open LockRight.
You forgot spool tool
Moph
Joined: Sat May 19, 2007 11:30 pm Posts: 2535 Location: Perth
Vehicle: 93 Sierra
 Posted: Thu Aug 26, 2010 12:08 am |
Geeze, you blokes are harsh! I've done 5000km on my Lockwrongs now and haven't had any real issues with them. You do have to take it a bit easier in carparks (reverse to first) and not get on the throttle when changing drive from one inside wheel to the other, but with mine and doing the above it is pretty much invisible. Slight tug either way when getting on and off the throttle at speed is about all that can be felt, and you soon adjust to that.
Hell, my wife even drove it 60km round trip to work and back, on 100kph highways, for a week while her car was elsewhere
MR1JZ
 Posted: Thu Aug 26, 2010 12:12 am |
I'm still going to fit it in the front I just don't have much faith in them in a diff that sees drive on the road all the time
shep
 Posted: Thu Aug 26, 2010 12:57 am |
hay atari. even a noisy lockright works better then your difflock at the moment hay.
i wonder if the people that keep slagging off at lockrights are just embarrassed that they spent 2 grand for a similar outcome.
atari4x4
 Posted: Thu Aug 26, 2010 1:25 am |
v6zookie
 Posted: Mon Aug 30, 2010 10:49 am |
