It is currently Fri Oct 30, 2026 1:59 am
Post Posted: Wed Sep 01, 2010 4:39 am
i need to know the ratios neede to run 35 inch tyers on hilux bundarah diffs and what ratio is needed for the transfer case thanks :x
Post Posted: Wed Sep 01, 2010 4:40 am
oh in my 87 sierra with vit 1600 carby motor
Post Posted: Wed Sep 01, 2010 4:47 am
6.5's in the trans and 5.12 in the diff , Cheers Paul.
Post Posted: Wed Sep 01, 2010 6:04 am
5.29 ratio for the bundy diffs as they are toyota,
1989 1.3ltr sierra hardtop. 2" lift small exo oran
Post Posted: Wed Sep 01, 2010 6:10 am
will thiss be super slow in low range
Vehicle: MY2019 Jimny
Post Posted: Wed Sep 01, 2010 6:36 am
Yes.
Vehicle: LJ20 LJ50
Post Posted: Wed Sep 01, 2010 6:58 am
first gear 3.65
low range 6.5
diff ratio 5.29
equals 125.05 reduction
so at 2000 rpm your rear wheels will be doing 16 revolutions per minute
assuming that a 35 inch tyre has a diameter of 2793mm that means your car will travel 44688mm (44.688 metres) per minute or 2681280mm (2681.280metres) per hour which equals 2.68 km/h
That is really slow enough. That is slower than walking pace.
Camels have nice toes
Post Posted: Wed Sep 01, 2010 7:07 am
TZAR wrote:
first gear 3.65
low range 6.5
diff ratio 5.29
thanks for ur help
Post Posted: Wed Sep 01, 2010 8:10 am
or the more common 4.88 diff gears
unless you are still using the bunderea front which is hi-pinion, finding 4.88 hi-pinion is harder
Vehicle: Nissan
Post Posted: Wed Sep 01, 2010 8:25 am
TZAR wrote:
first gear 3.65
low range 6.5
diff ratio 5.29
but you do have 5 gears :wink: :)
Pearce-toff Racing
Post Posted: Wed Sep 01, 2010 10:48 am
i had 1.6l carby
5 speed
6:1 xfer
5.29 diffs
37" tyres
revved - 4000 rpm @ 100kph
worked well, same as above there is five gears and about 6500 rpm to play with!
Post Posted: Wed Sep 01, 2010 10:57 am
My bundy diffs were 4.55 with HP front. With 36's and auto it was fine. Standard 75 series transfer gears.
Users browsing this forum: Google [Bot] and 119 guests
