It is currently Sat Oct 31, 2026 8:47 am
Post Posted: Wed Sep 01, 2010 4:31 am
Hi guys.
Car is a 98 sierra.
I have this whining noise coming from the engine. I thought it might have been the air con compressor, because i just had a mate regas it before we went to kakadu last weekend. It was the only thing that has been touched recently.
So i took the belt that drives the compressor off and fired it up. Same result :x .
Then i took off the fan belt and gave it another shot, this time no noise. :)
Problem now is that i don't know if it is the water pump or alternator. Tried spinning each of them by hand but i can't really tell.
Has anyone had this problem? or is there something else i can do to rule out one or the other?
Vehicle: Jeep
Post Posted: Wed Sep 01, 2010 6:08 am
milkhunter wrote:
Hi guys.
Car is a 98 sierra.
If its a bit like a squealing whine, then i would say water pump... try spraying some CRC or WD40 around the centre of the fan and Alt to see if that stops the noise, do one first, then try the other... but i would think it is water pump... :wink: :D
Vehicle: MY2019 Jimny
Post Posted: Wed Sep 01, 2010 8:16 am
Have you checked to see if someone's wife is stuck under your bonnet?
Post Posted: Wed Sep 01, 2010 8:25 am
:lol:
Vehicle: Suzuki Sierra
Post Posted: Wed Sep 01, 2010 12:45 pm
Does it have power steering? if it does could be low on fluid.
Vehicle: Sierra
Post Posted: Wed Sep 01, 2010 2:03 pm
Have you checked them for play? Not just spinning them?
Post Posted: Thu Sep 02, 2010 5:47 am
Thanks for the relies guys. A mate came around today (a mechanic) and put the stethescope (spelling) on it and its deffinately the water pump.
While im in there i might as well do the alternator upgrade as well. :)
Now i just have to find them, will be checking the wreckers tommorrow.
Thanks again
Post Posted: Thu Sep 02, 2010 5:51 am
Thanks again
Stethewhateverscope hey
I saw a mechanic put a long flatblade screwdriver onto areas of the engine once, with the handle to his ear
It seemed to work, and was amusing to see
Post Posted: Thu Sep 02, 2010 5:53 am
until it hits a fan blade...
Post Posted: Thu Sep 02, 2010 5:54 am
Like i said, amusing to see lol
Users browsing this forum: Google [Bot] and 461 guests
