It is currently Sat Oct 31, 2026 1:18 am
Post new topic Reply to topic  [ 48 posts ]  Go to page 1, 2  Next
Post Posted: Wed Sep 01, 2010 10:10 am
Gonna be looking at getting brand new pinion and ring gears soon. Just wondering which ratios to get. Was thinkin either 5.38 or 4.57. I have 6.5:1 transfer gears and 35 silverstones and is driven on the street
Post Posted: Wed Sep 01, 2010 10:59 am
Is this a question or a statement?
there are gearing calculators on various sites seach around a bit.
personally I think 5.3's and 6's in the transfer will be too low for a daily but thats why you need to work it out for your self, can you live with it.
Post Posted: Wed Sep 01, 2010 11:02 am
And? :roll:
Where are you getting these R&P's from?
Post Posted: Wed Sep 01, 2010 11:09 am
Not sure where I'll get them yet as lowrange seems cheap and Trail gear. Any links to the calculators
Post Posted: Wed Sep 01, 2010 11:10 am
Oh and it's a question????
Post Posted: Wed Sep 01, 2010 11:13 am
Check on availability first. These things can be hard to get hold of somethimes....
Post Posted: Wed Sep 01, 2010 11:22 am
Yea I noticed the 4.57s were out of stock
Post Posted: Thu Sep 02, 2010 12:23 am
Check on US E-bay for "Samurai Gears", there are heaps of listings of both ratios all the time from a variety of sellers.
But why go those particular ratios? You could find a set of Vit 5.125 or 4.625 gears here for a fraction of the price..
Post Posted: Thu Sep 02, 2010 2:04 am
Shipped to Newcastle, Low Range Offroad wants like $600AUD for 2x 5.38:1 R&P gears
Best value ANYWHERE
Ebay is ~$700-750AUD
And Locktup is around $900AUD
Post Posted: Thu Sep 02, 2010 2:38 am
is there any thing for 1.3 diffs around 4.1 to 4.5 ratio?
Post Posted: Thu Sep 02, 2010 2:40 am
4.6something, next lowest is 3.9
So no luck Shep
Atleast not to my knowledge
4.1 from a maruti WT.
4.3 from vitara (GV?)
4.6 from vitara
Post Posted: Thu Sep 02, 2010 3:07 am
There is a list somewhere on here, all 1.3 size diff ratios. Tried searching for 10minutes..cant find it. I know i made some of it..
Post Posted: Thu Sep 02, 2010 3:10 am
how hard are the 4.3 R&P to find.
Post Posted: Thu Sep 02, 2010 3:53 am
Easy mate.... Directly under the engine between the front wheels............................
In the right car of course.... :roll: :wink: 8O
Vehicle: Zookless
Post Posted: Thu Sep 02, 2010 3:56 am
The 4.3's you want Shep are Vit front R&P's.
http://www.auszookers.com/index.php?nam ... light=diff
I've been looking for some for about 2 years now...
Post Posted: Thu Sep 02, 2010 4:09 am
In order or rareness ( is that a word?? :D )
4.3 vit
4.1 maruti
4.6 vit
5.12 vit.
What makes life hard with the vit R&P's is you need the front gears from 2 vitaras, not just one. :?
Post Posted: Thu Sep 02, 2010 4:39 am
I was looking at brand new ones because I don't wanna have them break again soon
Post Posted: Thu Sep 02, 2010 5:32 am
New or old, when your bound up on a rockface, they will let go.
Post Posted: Thu Sep 02, 2010 5:48 am
Doubtful, stock CVs and Axle Splines will fail before R&P Gears do
That said, Spider Gears are generally weaker than R&P anyway, not to mention they cop alot more abuse on rock.. Unless you're locked up!
Post Posted: Thu Sep 02, 2010 6:27 am
I have never snapped a axle or a CV, but i've broken a few centres, one which was smashed ring and pinion teeth, i even watched a mate do one on his hilux a couple of months back, bit too much throttle, one wheel in the air, the wheel touched down and *bang*... seven teeth gone. CV's and axles still look like new. (thats was on 29's and standard everything).
Vehicle: 1992 sierra
Post Posted: Thu Sep 02, 2010 6:41 am
4.3 vit
4.1 maruti
4.6 vit
5.12 vit.
Rarity :wink:
Post Posted: Thu Sep 02, 2010 6:46 am
I know of some 4.1 maruti's floating around, my mate has them, but now has lux's diff's.... interested?
Post Posted: Thu Sep 02, 2010 7:03 am
fuggen oath pm sent
Vehicle: Zookless
Post Posted: Thu Sep 02, 2010 7:32 am
Good score there Shep. :D
Anyone else got any that are lower than stock?
Post Posted: Thu Sep 02, 2010 9:41 am
I have a customer (who is also a friend) with a 2009 Jimny. We have given it a little lift, and supplied some 15x6 black steelies with 235/75R15s.
It now needs ratios & traction control.
Any advice? He tells me that his high pinion front and low pinion rear contain 4.3:1 gears.
Post Posted: Thu Sep 02, 2010 9:48 am
my tyres are nearly worn out and i want bigger for the next ones, now i wont have any excuse not to go 33's. :D
Post Posted: Thu Sep 02, 2010 10:01 am
It's very unlikely it has 4.3 gears. Whilst the brochure said that 4.3's were possible on automatic Jimny's, apparently nobody has every seen any, so they're generally all 4.1.
Whilst the rear of a jimny is the same as sierra, so can run any ratio a 1.3 sierra can, the front of jimny is unique to the jimny.
There are some ways to run a sierra diff, but it's pretty much a fabrication project and requires steering modifications etc. (because there's no high pinion sierra diff)
I'd be looking at leaving the diffs alone and fitting a gear driven sierra transfer case. It's a bit complex to do, and not all that cheap if you sort the speedo drive and have to buy parts, but it will fix both high and low range nicely.
With 235 tyres, even stock gearing would be fine, or some 4:1 transfer gears would be sweet with lockers in the diffs.
Others may have a different take on the solution.
Post Posted: Thu Sep 02, 2010 10:39 am
Thanks for the advice. Now the search starts. ;)
Post Posted: Thu Sep 02, 2010 10:43 am
opinion does not equal advice, the 4.3 gears are pretty easy for a v6 to smash in a GV
Users browsing this forum: No registered users and 354 guests
