It is currently Mon Nov 02, 2026 10:48 pm
Post Posted: Thu Sep 02, 2010 8:47 am
Going to look at a Jim tomorow. What in particular should i look out for. What should i steer clear of if i see it.
Also whats a rough price i should be looking at? its a 02 so no vvt, but <100,000km stock
Post Posted: Thu Sep 02, 2010 9:27 am
Overall check. Oil leaks/colour, water colour. Depends what your buying im for. Look for underbody damage. 4wd works. Cvs clicking at full lock. Etc. The motors purr like a kitten. Very smooth.
Post Posted: Thu Sep 02, 2010 9:48 pm
Check for King Pin movement by jacking the front wheels off the ground (can be one at a time) grab the tyre top and bottom and try to wiggle it back and forth, if you can feel movement it's either the wheel bearings or King Pin bearings.
Take on some dirt when you test 4WD. If it engages properly you should get little or no wheel spin when you accelerate fast. The Auto hubs are known to develop faults.
Look for signs of water in the Air filter box.
Gearbox and transfer case develop leaks around the shaft outputs, so look for oil around them and on the underneath of the cabin floor.
If the Jimny has had a problem with the crank angle sensor which would cause back-firing the Catalytic Converter may be blown through. Hit the muffler with your palm to see if you can hear loose crap inside. If so you may need a new exhaust from the Cat back. The loose crap inside can develop to a severe blockage.
If the motor sounds rough it could just be worn belts. Check them, if they're worn it could be a sign of poor maintenance habits of the current owner.
If I think of more, I'll come back.
Users browsing this forum: No registered users and 443 guests
