It is currently Fri Oct 30, 2026 7:57 am
Post Posted: Thu Sep 02, 2010 3:05 pm
Ok whos got one and has painted it.
Mines looking a lil sunfaded and sad, but with it being fibreglass I have no idea how to prep, prime and paint it.
Or should I take it somewhere to have it re gel coated, etc?
Any suggestions?
Post Posted: Thu Sep 02, 2010 11:59 pm
Any suggestions?
Sell it to me :D
Post Posted: Fri Sep 03, 2010 12:04 am
Also doing the same thing would like to know....
My Maruti build, Click WWW
Post Posted: Fri Sep 03, 2010 12:14 am
Any suggestions?
Sell it to me :D
mmmmm....lemme think
no
Post Posted: Fri Sep 03, 2010 1:00 am
ninjamoses painted the fiberglass canopy on his vitara, i think getting the gel coat redone would be pretty pricey... swing past a boat builders & see what they suggest.
Post Posted: Fri Sep 03, 2010 2:21 am
hey Chopz how hard are they to come by i havnt really look but i would tend the think there rare ?
Vehicle: '96 LWB trayback
Post Posted: Fri Sep 03, 2010 3:46 am
Mine was painted by the previous owner. The glass is pretty fragile and tends to result in the paint cracking off it there is any dings or impact.
If you're going with a standard sort of colour available in gelcoat, it would probably be a better option.
If painting, best get your prep methods sorted properly.
Post Posted: Fri Sep 03, 2010 5:22 am
mine was also painted by the previous owner, mine sounds a little stronger then yours, its the same paint the front are rear bars are painted, im assuming the used a metal based application paint and it seems to stick fine of the firbe glass. not sure of their prep work sorry
Post Posted: Fri Sep 03, 2010 6:31 am
oozuk painted his, it says somewhere in his build thread what he done to prep it for paint
OOZUK
Post Posted: Fri Sep 03, 2010 7:15 am
pretty rare.. get ready to hand overabout $600.
Post Posted: Fri Sep 03, 2010 8:59 am
OOZUK
Found it.
He says.
"nah you just use sotchbrite sanding pads as part of the process when rubbing it back and do it with soapy water that way it gets in all the cracks and crevices.
I first used a air random orbital sander with 180 grit dry to smooth out the textured look of the fiberglass roof"
Post Posted: Fri Sep 03, 2010 10:23 am
very hard. mines a stockman, so they come with them from factory
i thought there was a few people who had painted theres on here for some reason, maybe i'll have to try the boat builders or something then
Post Posted: Fri Sep 03, 2010 10:32 am
Painting fibreglass is much the same as painting steel...
Sand well and use a good primer then topcoat & clear (if desired/needed).
Post Posted: Fri Sep 03, 2010 5:46 pm
I geuss gel coat would provide a harder longer lasting finish but may be a bit expensive.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Users browsing this forum: No registered users and 311 guests
