It is currently Mon Nov 02, 2026 9:49 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
Post Posted: Sun Sep 05, 2010 9:18 am
Ok so the coily is almost back on the road (for now :lol: ) and I am looking at upgrading my rubber.Now before anyone says use the search button.....read :roll: and then tell me that!
Few questions...Preferably from guys with experience,and guys with coilys(haha I said it!!) but advice on the topic is welcome...
Ok my rig..turbo gti coily,2inch body and suspension lift,Virtual lift with TJ jeep flares...I will be looking at running 6.5's in a wt case.
1.What size tyres are you coily guys running,and are you happy with them(ie would you go bigger/smaller)?
2.What rims/offset are you running?
3.Will the coily diffs handle 32/33's?if not why?
4.I was looking at maxxis bighorns or bf goodridge m/t,any other alternatives you guys are running?
And lastly has anyone done the wt diffs into coily for the sake of airlockers ect.(and is there a 3.9 center available for them or would I just go lower?) Sorry don't know much about diff ratios.
Coily GTI Turbo...thats right its a coily!!
Post Posted: Sun Sep 05, 2010 9:21 am
Count's me out!! :roll:
Post Posted: Sun Sep 05, 2010 9:22 am
Ahh dont be like that...tell me what you know... 8)
Post Posted: Sun Sep 05, 2010 9:27 am
ok I'll give you the mail, coily's are crap :wink:
but either of those tyres are top tyres, the maxxis are a fair bit cheaper
Post Posted: Sun Sep 05, 2010 9:28 am
you need to tell us more specifically the terrain you drive and what percentages of each.
as for size, stick with 31's for reliability IMO.
Post Posted: Sun Sep 05, 2010 9:29 am
I'm yet to see a Maxiss off a rim, what are the side wall's like?
Do the bead's seat tight?? Or are thay like other cheap tyre's & fall on??
Post Posted: Sun Sep 05, 2010 9:37 am
good side walls
Ive had both and I'm running the km2 bfg at the moment, but I'd say the maxxis is a slightly better offroad tyre all round and great on road.
the bfg is exellent on road and great off road, the maxxis is better in the goop. bfg is a little quiter than the maxxis.
both wear very well for muddies I got 70km from the bighorns and will get something similar from the bfg's i guess.
both are a top tyre but I'd lean toward the bighorn just for the $200-$300 a set difference.
Post Posted: Sun Sep 05, 2010 9:44 am
i drive a coily, 2 inch suspension and 2 inch body lift. Its my daily driver and i do mostly rocky, gravel and sand off road driving. i run 30 inch kumhos kl71s and i think they are a great tyre. plenty of grip on road in wet and dry, awesome off road in most conditions..im yet to see how they wear but so far they have been really good. i have 15 x 7 -13 offset sunnys.
Post Posted: Sun Sep 05, 2010 9:50 am
I dont know about the more consumer type sizes but teh 37" comp compound trepadors are fucking heavy and fucking hard to get on a rim when its 4 degrees and need that much air to seat you start to think about backing away slowly :)
ive had nothing but goodyears for 4wd tyres but might consider them next time round
Post Posted: Sun Sep 05, 2010 9:54 am
Cheer's royce, some of the cheaper tyre's seat if you fart near em.. :roll:
Post Posted: Sun Sep 05, 2010 9:57 am
cheers guys...sooo leaning towards the maxxis..my brother in law runs them,and it made a huge difference in the mud/rock...I will be running over,mud,rock,sand,everything really...
Anyone else recommend the 31's for reliability?
Post Posted: Sun Sep 05, 2010 10:37 am
I would not go any bigger then 31s on coily diffs.
1. You can not get chromo axles and cvs, for the coilys.
2. Spare parts for the diffs are hard to find
3. They are expensive if you do find them.
4. Even more expensive if you buy new.
I can run a full size 31" with my gearing, 4.9s and 3.9 diffs.
You will want to reinforce your radial arm mounts on the diff, they have a habit of tearing off when you add a locker and gears :wink:
Post Posted: Sun Sep 05, 2010 11:05 am
So would it be worth doing a w/T diff swap front and rear???
Post Posted: Sun Sep 05, 2010 11:14 am
It would just be shit loads easier to run 30's and not have a problem. Screw converting the front diff over to run an extra inch of rubber. Maybe if you were going to run some 33's or bigger 8)
Post Posted: Sun Sep 05, 2010 11:15 am
i run 31'' mt baja claws, around the same noise as the maxxis, yet a hell of a lot better in the sand and the mud, plus with get pretty good kilometers out of them.
my choice is 31x10.50 baja claws on a 15x8 offset 22.
i think there a great all rounder on a zook
dodgy brothers mechanical
Post Posted: Sun Sep 05, 2010 11:18 am
what a load of bullshit and your about 12 yo and been driving for 5 minutes.Yep you know a lot about tyres don't you.
Post Posted: Sun Sep 05, 2010 11:19 am
Baja Claws = :no: :no: :no:
Post Posted: Sun Sep 05, 2010 11:21 am
I agree, claws are shit and maxxis is the shit. my buckshots are a hell of a lot better than the claws that I tried. The claws were new and had less traction than my buckshots do.
Post Posted: Sun Sep 05, 2010 11:28 am
30" Bighorns mate, I've got a coily too so I wanna see how you go :P
helloo
Post Posted: Sun Sep 05, 2010 11:32 am
Mate I'm running 29's and no lockers or gearing and I still need to beef up the mounts.
Unique go through Fatzook and he should get you some 5mm brackets cut up for your coily before you go wacking on some big rubbers. Otherwise you might lose a diff somewhere on the tracks :P
helloo
Post Posted: Sun Sep 05, 2010 12:19 pm
IMO no. It would be a huge amount of work for not a lot of gain. Stick with 30s / 31s and add a rear locker and gears.
lockie, it depend on how you drive and there condition e.g. rust, age etc. The mounts are only made from 2mm sheet with a weak design :roll: The front mounts are much stronger
Post Posted: Sun Sep 05, 2010 12:42 pm
no im not 12. and been driving alot longer then 5 mins, plus working at a 4wd shop i get to here alot of feed back on different tires mate.
and every body is entitled to the opinion.
but mine is claws so get over it
Post Posted: Sun Sep 05, 2010 12:58 pm
You are entitled to your opinion.
But you are in the minority :wink:
Claws may be perfect for your chosen driving style and terrain, but most with sierras and vits will find them to be less effective than other makes of tyre.
Post Posted: Sun Sep 05, 2010 10:24 pm
im running NEXEN Roadian MT on 15x8 Mega Offset rims and Cant fault them at all they r 31x10.5x15s
Alot cheaper than the Maxxis and BFGs
819FKA has Been UNLEASHED
Post Posted: Sun Sep 05, 2010 11:55 pm
these arent badly priced either, and will be my next tyre:
Definitely more of an all-rounder than either of the 2 mentioned. By reviews i've read online theyre deceivingly good in mud and great on everything else.
Post Posted: Mon Sep 06, 2010 12:07 am
not to sure if the general grabbers are road legal tho. they might be but from what im told the arent. could be wrong tho
Vehicle: SJ80, SE416
Post Posted: Mon Sep 06, 2010 1:55 am
My experience with 31" Maxxis Trepadors on a coily:
-13 offset (or deeper) with only 40mm spring lift and 2" BL results in tyres fouling with the edge of wheel arches at full flex. The Coily axles are longer then WT so a smaller offset will see a nice improvement in track width.
The radial (not the comp ones are bias ply) Trepadors have a really light sidewall IMO. With inner tubes and 6PSI I was very impressed with how flexible they are. I don't have other tyres cut open to compare the sidewall to, but I put a 3" slash in the sidewall of one of mine after only 2 hours total driving. Maybe I was unlucky?
I need some new tyres on my daily drive soon and I am considering the smaller trepadors if I can get them. I am impressed with their on-road abilities - mainly in the wet as they actually seem to have pretty good tread siping and they stop much better then other MTs I have driven on.
I have broken 2 CVs in my coily - one on 29s (being a bit heavy on throttle and brakes while stuck) and an already clicky one on 31" swampers. I don't think they are any weaker than leafy ones. I have also torn a rear diff mount but if I was too worried about breaking it again I could reinforce it.
I haev seen MT baja claws at work and they suck IMO.
Vehicle: LWB Sierra
Post Posted: Mon Sep 06, 2010 2:15 am
Hey Guys,
Does anyone have any opinions on the Silverstone MT's and what kind of K's you'd get out on them?
Trying to toss up between the Maxxis Bighorns or the Silverstone MT's.
Only reason why i am considering the Silvers is that i can get them for a very nice price.
I don't do much wheeling at all but would like to in the future - basically mud and rocks etc no sand.
Thanks,
Andrew
Post Posted: Mon Sep 06, 2010 6:10 am
I'd go Bighorn of Silverstone MT... better construction.
as for the generals - theyre a radial and are DoT approved and legal.
Post Posted: Mon Sep 06, 2010 7:10 am
I run 30" Treps and absolutely love them. :twisted: I have constantly compd the car over the last
12months with these tyres on and the worst I have done is rip a radius arm off the diff and snap a rear one in half. Personally haven't had problems with CVs yet (touch wood).
But I run two open diffs with standard gearing, I give it a fair bit of shit when I need to. :wink:
Users browsing this forum: Google [Bot] and 109 guests
