It is currently Fri Oct 30, 2026 3:42 pm
Post Posted: Sun Sep 05, 2010 7:30 am
ARGHHHH! Since a few week ago when i changed my leaves and repositioned the steering wheel (it went a bit crooked with the lowered height) its been squeaking just at one point of the turn of the wheel - about 1/8th - 1/4 turn right hand down... its a horrible sound too, nails on a blackboard type stuff.
I've tried backing off the nut on the wheel, removing the wheel completely and established that it still squeaks even without the wheel on it (using a spanner on the nut to turn it). I've smothered with spray on lube (inox) down into the column and its still doing it!!!
Its definitely in the vicinity of the indicator stalks as listening further down its coming from higher up.
Any ideas? its bloody annoying!
Cheers =)
Post Posted: Sun Sep 05, 2010 7:44 am
Horn contact!!!
Post Posted: Sun Sep 05, 2010 7:49 am
silicone spray ;)
only a bandaid but works.
Vehicle: Clown Car..
Post Posted: Sun Sep 05, 2010 8:31 am
im shitty at my light switch stalk.. the actuall switch bit tends to vibrate in the off position, giving off a REALLY annoying tic. turn it so lights are on.. .. tic goes.. ended up wrapping the end of the stalk in heat shrink.. Fixed :D
sorry cant help with your steering squeek.. keep rippin bits off.. it will eventually stop.. :LOL:
Post Posted: Sun Sep 05, 2010 8:51 am
shakes wrote:
silicone spray ;)
electrical contact grease would work better & longer but would mean taking your wheel off again..
The lil contact that rub's on the steering wheel wear's down over time, I have in the past put solder on the end of the contact, it wear's quicker that copper but is quite..
Or rip it out & fit a horn button.. :lol:
Post Posted: Sun Sep 05, 2010 9:04 am
steak_knife wrote:
shakes wrote:
silicone spray ;)
x2 on the electrical grease
Post Posted: Sun Sep 05, 2010 9:30 am
how can it be the horn though if it still squeaks when the wheel is off???
Post Posted: Sun Sep 05, 2010 9:37 am
:? Telepathy?? :?
missed that bit, from memory there is a bearing in the top of the column, you may of damaged that during removal..
Post Posted: Sun Sep 05, 2010 10:45 am
steak_knife wrote:
:? Telepathy?? :?
ha ha ha telepathy, thats f*ckin gold :lol: :lol:
Post Posted: Sun Sep 05, 2010 10:41 pm
ROFL nice =)
ok - so how does one access that bearing??? is it a dash out job or is there a way to get to it easier?
Post Posted: Mon Sep 06, 2010 10:23 am
*bump* its really very annoying.
Post Posted: Mon Sep 06, 2010 10:27 am
you have to remove the column, there will be a circlip on the shaft (firewall side from memory). remove it and the shaft will come out.
Post Posted: Mon Sep 06, 2010 11:57 pm
so wheel on, remove circlip from engine side of firewall, pull on wheel to pull out whole column?
Isnt there more to it? lol sounds scarily simple =)
Post Posted: Tue Sep 07, 2010 9:12 am
I had a look in the manual today & book say's not serviceable..
But the one pictured did look like a collapsible one,P/s maybe..
Post Posted: Tue Sep 07, 2010 10:05 am
i thought all sierra columns were collapsible?
Being that its steering i might take it to a professional to get looked into when i get the chance... not something i want to be messing with if theres risk of failure.
Post Posted: Tue Sep 07, 2010 10:32 am
a good trick is to drill a tiny hole in your column just before the bearing /bush and spray some silicone lube into it quick simple fix :wink:
Users browsing this forum: No registered users and 412 guests
