It is currently Thu Oct 29, 2026 5:45 am
Post Posted: Fri Sep 10, 2010 6:00 am
hey guys just wondering whats the best way to remove the drag link out of my car i tried a hammer and it didn't budge its on their good... any ideas? cheers
Post Posted: Fri Sep 10, 2010 6:12 am
have you got a ball joint remover? or a tie rod end remover?
otherwise, put alot of leverage on something between the chassis and the draglink, then hit the joint (NOT THE THREADED STUD) and push down and hope it budges.
i hate doing it and will purchase a tie rod seperator for the next time i need to do it.
Post Posted: Fri Sep 10, 2010 6:21 am
2 hammers..
Ok lets see if I can explain this well enough...
at the same time swing both hammers from opposites directions towards each other with the joint in between them give a few smack like this and it will "shock" the ball joint apart.
Works every time. May want to soak with CRC or similar overnight before you start.
255 characters
Post Posted: Fri Sep 10, 2010 6:23 am
I bought a ball joint remover thinking it was gonna solve my problems... Piece of stinkin crap... useless thing! :P
255 characters
Post Posted: Fri Sep 10, 2010 6:43 am
I use the two hammer method as well, but i hold one hammer against the side of the ball joint and hit the other side of the ball joint with the other hammer.
It will achieve the same result but thats the way i have always done it.
Sam
92 WT, 31" buckshots, half RUF and 6.5:1.. Low and
Post Posted: Fri Sep 10, 2010 6:45 am
had this same problem the other day i tired a BFH, wd40, crc, blow torches and yelling at then i got a 3 jaw bearing puller.
it will cost about $30 but it is money well spent. i have already used it to pull pitman arms, tie rods and drag links from steering arms and knuckle caps.
Vehicle: 07 vvt jimny
Post Posted: Fri Sep 10, 2010 7:02 am
sorry man i should have told you before you left, if you get stuck i have a 3 jaw puller here u can borrow. mine was a bastard to get out
sorry CHOP :P
Jimny's Are taking Over
Post Posted: Fri Sep 10, 2010 7:16 am
If you need a hand Luke, bring it over and I'll show you how to remove it with only a hammer(and pliers for splitpin and spanner for nut).
I guarantee it'll be free in less than 3 blows.
Post Posted: Fri Sep 10, 2010 8:39 am
I was going to ask if he unbolted it.. :lol:
Post Posted: Fri Sep 10, 2010 9:27 pm
alright well ill bring it around when i come to do my unis as well :P and yes i unbolted and removed split pins. i have a ball joint splitter at home
Post Posted: Fri Sep 10, 2010 9:31 pm
i have a great fitting that goes in a air chisel. nothing has stopped it yet. :D
Post Posted: Fri Sep 10, 2010 9:33 pm
I've always found a few good hard blows in the right place frees them up pretty quick. But you must hit in the right place or it will all turn messy :lol:
Post Posted: Fri Sep 10, 2010 10:19 pm
If the others have not been clear enough, DONT hit the threaded stud part OR the balljoint that is attatched to the stud. Hit the part with the hole in the middle where the stud goes through. The hole is tapered and when its hammered the metal flexes a teeny bit, enough to squeeze the stud and balljoint out like a teeny turd.
Users browsing this forum: Google [Bot] and 286 guests
