It is currently Thu Oct 29, 2026 10:53 am
Post Posted: Sat Sep 11, 2010 10:54 am
i know that hilux/commodore are the go for 2 inch but what do people use for higher lifts?
i am topping out the commo shocks that i have in the front and my rears are stuffed calmini jobbies.
i would like to be able to walk into a stupidcheap and just pick up something that works, if possible.
Post Posted: Sat Sep 11, 2010 10:56 am
http://www.gabriel.com/
:P
Post Posted: Sat Sep 11, 2010 10:58 am
:P
Thay don't seem to list length's tho, prick's.. :evil:
Post Posted: Sat Sep 11, 2010 11:01 am
steak_knife wrote:
:P
i have spent hours with dickhead parts interpreters trying to find rear shocks,
they don't seem to understand that i don't want sierra shocks. :roll:
Post Posted: Sat Sep 11, 2010 11:05 am
You see, thay interpret part's, & have no fucking idea how to communicate with people.. :lol: :lol:
Part's don't confuse them by wanting thing's that don't match the Vin.. :P
Post Posted: Sat Sep 11, 2010 11:58 am
what length do you need shep? Gabriel do have their lengths listed somewhere...
Post Posted: Sat Sep 11, 2010 12:04 pm
i need 60mm longer then the vs KYB jobbies that i have on now and i would need to pull a rear out and remeasure it.
from memory it was 690 or 790mm, fairly long anyway.
if i get time tomorrow i will yank one out and measure it.
Post Posted: Sat Sep 11, 2010 12:06 pm
I got a mate that works at supercheap, I'll see if i can get a catalogue that actually has lengths on it. I found a link to the old catalogue of the gabriel stuff but it is dead now.
Post Posted: Sat Sep 11, 2010 12:07 pm
good on ya mate i will put some effort into actually measuring what i need. :roll: :lol:
Post Posted: Sat Sep 11, 2010 12:12 pm
using the hiace/lux and commy shocks with 2" isnt ideal.as you know using 50mm spacers up front and 40mm on rear as i do.the extra height with your 4" lift may help here without the need to do bumps?
or i dunno :oops: just go spend 20mins with it flexed up and go from there.
edit:the height wont really make any difference will it.i have to get motivated and one day cut my mounts and move them up to lose the spacers
Post Posted: Sat Sep 11, 2010 12:20 pm
this is with VS shocks and they bottom and top out. if i jack the front of the car
up off the front bar until both wheels come off the ground, pulling a shock out
lets the diff drop another 50mm.
maybe i need to make some sort of ramp and measure it properly. :?
Post Posted: Sat Sep 11, 2010 12:22 pm
surely there is an 80 series or something broken that you can use as a ramp
Post Posted: Sat Sep 11, 2010 12:40 pm
i don't like my car touching Toyota's in case the awesomeness gets transferred to the Toyota. :wink:
Vehicle: LJ20 LJ50
Post Posted: Sat Sep 11, 2010 1:03 pm
http://www.monroe.com.au/trade-corner/catalogue.html
It has the extended and compressed lengths of all applications in the back of the book under Numerical listings.
be a pain in the arse searching but beats dealing with guys that can't understand the concept that you might want something out of the box.
Camels have nice toes
Post Posted: Sat Sep 11, 2010 2:14 pm
Try commo sedan instead of wagon. Notably longer. I have them on the Sierra, but run about 70mm of bumpstop extension (which you may not want?), I cannot get the springs to use all the shock length (mind you I am not 4" lifted, probably closer to 3 or just under). Very similar length to what I think are LH Torana rear, which one of my LJ81s had on the front when I bought it.
Can't help with rear, as mine suck :lol:
Clearance Hole Technology :P
Post Posted: Sat Sep 11, 2010 8:21 pm
Defender for the rear but needs to be laid over, Triton might be another option
yep commondore sedan is longer, not sure if they have more travel though but I reckon either way you are going to need to make hoops or something
Post Posted: Sat Sep 11, 2010 8:46 pm
there is a triton at the dump so i might grab a shock and see what it is like.
front shock hoops are probably next :roll: i am buying a good mig so hopefully my welding will improve
Vehicle: LJ20 LJ50
Post Posted: Sat Sep 11, 2010 8:49 pm
Users browsing this forum: Google [Bot] and 332 guests
