It is currently Mon Nov 02, 2026 11:45 pm
Post Posted: Sat Sep 11, 2010 9:41 am
How much power would you be able to run through a sierra transfer case without expecting an explosion? It would be standard gears, most likely 1L, as most of the gearing for the vehicle will be done by the diffs. Looking at running an auto with it as well so it isn't as harsh on the transfer and driveline.
Would a theoretical 200kw be pushing it?
Post Posted: Sat Sep 11, 2010 9:56 am
I would think 100Kw would be pushing the friensdship.
200 is asking for trouble.
Post Posted: Sat Sep 11, 2010 9:59 am
http://cgi.ebay.com.au/Suzuki-Sierra-V8 ... 946wt_1137
This thing has a 253 & a 1.3 transfer for"lower gearing"
The 20v 4age's with Haltec's push 100kw & thay don't seam to smash case's to often..(Bruskibilt boy's)
Vehicle: MY2019 Jimny
Post Posted: Sat Sep 11, 2010 10:37 am
It is more driving style than brute HP. Also depends on whether the Tcase is stock or not, and if it is braced or not.
Post Posted: Sat Sep 11, 2010 11:27 am
I split one with 140hp atw. No big launches I was just taking off from the lights and buried the foot in first gear once I was moving, boost came in and transfer split in two ...... Bugger
Now the new one is fitted with a mighty kong and a rocktoy ring, all good now
Post Posted: Sat Sep 11, 2010 11:54 am
have you given it a good go with the new reinforcement? like in similar circumstances of what broke the old case?
the plan in my head is to run a 13b rotor, using the auto box and sierra transfer. just want to see if it is plausible or if i would need to utilise a toyota gearbox/transfer combo
Post Posted: Sat Sep 11, 2010 1:09 pm
EDIT: Cleaned up post
Power (W) = torque (Nm) x angular velocity (rad/s)
rad/s = rpm x 2 x 3.14 /60
It isn't the power which opens the transfer cases, its the torque.
at 200 kW at say 7000 rpm
Torque at the flywheel will be
Torque = Power / Angular Velocity
Torque = 200 000/ (7000 x 2 x 3.14/60)
Torque = 273 Nm.
Now say you are in first gear (ratio for example will be sierra 1st gear 3.652).
Torque on gearbox output shaft is approx 273 Nm x 3.652
This torque is almost 1kN.
As we saw the other day
http://auszookers.com/index.php?name=Fo ... ic&t=14850 a torque of 1kN through the box is enough to make it go pop. IMO his case opened up like paris hilton due to the torque generated at the gearing interfaces.
6.5s in high range or not, the load the case can handle is the same.
Further example using a stock 1.3L in first gear
High range output = 1 kNm x 1.409 = 1.4 kNm
Low range output =1 kNm x 2.268 = 2.3 kNm
Gearing interface loads
high range
44 to 41 = 1k Nm x 0.93 = 0.93 kNm
41 to 62 = 0.93 kNm x 1.512 = 1.4 kNm
Remember sierra cases are designed for 47kW, which would normally generate 1/4 of the torque you are looking at. The 47kW motor can still bust the transfer case.
It would probably be wise to scrap the sierra xfer case idea and use one designed for more power.
EDIT: even with diff gears, the load will still be too much. You could consider hilux cases coupled with diff gears.
spending big on reinforcement is fairly silly, engineer it properly the first time. Select the diff ratios and transfer case which is suited to the loads you will be applying.
I'm not even certain the cvs and axles will hold.
High range is 1.4kN x 5.12 diff ratio = 7.2 kN.
Post Posted: Sat Sep 11, 2010 2:57 pm
1st gear (ratio for example will be sierra 1st gear 3.652).
Torque on the gear box output shaft will be
Torque = 273 Nm.
Now say you are in first gear...
Ratio is
As we saw the other day, a torque of 1kN through the box is enough to make it go pop.
You're correct that it is torque that gearcases are rated for, not power. At the rev range that an engine produces max Power, it may not be producing it's max Torque (in fact, definately won't be). It's the max torque figure you have watch.
But to get your figure of 1kN torque on the gearbox, why have you multiplied it by 3.652 twice?
It should be flywheel torque x gear ratio=output shaft torque, so a stock 1.3 is: 100Nmx3.652=365.2Nm going in to the case and x2.268 gives 828.2Nm in lowrange.
A G16B EFi has a max torque figure of 132.4Nm, so in a Sierra with 6.5s, we're looking at 132.4Nmx3.652(1st)x6.5(lo)=3142.9Nm load on the T case housing, a massive increase of 279% of what the case was designed to cope with.
Post Posted: Sat Sep 11, 2010 3:09 pm
Torque = 273 Nm.
Ratio is
I didnt mulitply it twice by 3.652, only the once.
I mentioned it twice, was a messy post on my behalf I appologise (lack of sleep). My OP in this thread has been edited and structured better.
I was basing the calcs on power stated by OP, using sierra 1.3 1st gear as example with 1.3 stock xfer gears (as in high range these generate the lowest torque output).
And from the link I posted, we know the ball park power, hence torque, hence case load in high range.
It is clearly obviously in low range it will not last, let alone with other gears.
EDIT: I am also aware of torque and power output characteristics, however from the OP that is unknown, so is rev range, so is gear ratio
Post Posted: Sat Sep 11, 2010 10:16 pm
are you going to make it a 4wd race car? sick bra :D
Post Posted: Sun Sep 12, 2010 7:01 am
looking at making it a winch challenge car. I agree with lump_a_charcoal that driving style is better than all out horsepower BUT in this event two out of ten stages, so 20%, where hill sprints where it is nothing but horsepower that will win you the race.
I was also looking to the rotary because they are light, small, make awesome power, rev well and the torque isn't half bad either. I have a yota transfer and a 5 manual box but i was hoping to stick with sierra stuff if possible.
Thanks for doing the physics guys, I was going to do that but the latest physics assignment is due and well i'm sick of it :D
Post Posted: Sun Sep 12, 2010 7:06 am
8O really?? 8O
Post Posted: Sun Sep 12, 2010 7:14 am
I have heard of series 1 rockhoppers surviving with rotaries
how about a miss match of mazda gearbox and transfers till something fits together?
Post Posted: Wed Sep 15, 2010 10:00 am
yeah royce I think that is how I will have to do it.
Users browsing this forum: No registered users and 131 guests
