It is currently Mon Jul 13, 2026 12:54 am
Post Posted: Sun Sep 12, 2010 12:35 pm
im pretty sure my front diff is on the way out so im after a new one i have a nt not sure if wt diff will fit? any info would be good, i also happy to organize postage if needed
Post Posted: Sun Sep 12, 2010 12:36 pm
WT will fit, but they are a different ratio.
What makes you think your front is on the way out?
What do you mean by on the way out?? Centres will fit but NT and Wt have different ratios...
Post Posted: Sun Sep 12, 2010 12:38 pm
That is not on, you literally took the words out of my mouth
Post Posted: Sun Sep 12, 2010 12:41 pm
Are you looking over my shoulder or something? :lol: :lol:
Post Posted: Sun Sep 12, 2010 12:45 pm
What I wouldn't give right at this moment to be able to tap on your window and watch the look on your face :shocked: :P
Post Posted: Sun Sep 12, 2010 12:49 pm
when in 4wd and if im not accelerating, ( rolling down a hill or something) i get this rattle / shack that comes from front of the car and up to the transfer case , i have changed the t case and checked the uni joints and there fine so im thinking it has to be the diff. also does it matter that they have differnt ratio
You'd be cleaning up the mess my friend :lol:
Post Posted: Sun Sep 12, 2010 12:51 pm
Check the usual suspects first...bushes, bearings etc
It could be a bearing.
And yes it absolutely matters if they are a different ratio!!
Must be the same, or you will break shit VERY quickly :lol:
Post Posted: Sun Sep 12, 2010 12:52 pm
got new front bearings too
Post Posted: Sun Sep 12, 2010 12:54 pm
Wheel bearings? King pin bearings? Pinion or carrier bearings?
Does the flange on the diff centre have movement in it? Unbolt shaft to check I guess
Post Posted: Sun Sep 12, 2010 12:58 pm
wheel bearings. yea there is abit of movement if i turn the front shaft while the diff is locked in i get about 1 cm play each way
Post Posted: Sun Sep 12, 2010 1:03 pm
What about up and down movement? Not rotational movement.
The slop that you mentioned above is backlash, or lack thereof.
Post Posted: Sun Sep 12, 2010 1:06 pm
so does it sound like the diff its fine when under load but if rolling it shackes and i hear a rattling noise
Post Posted: Sun Sep 12, 2010 1:10 pm
could be yeah. Have you drained the oil and checked for metal filings? If there has been a bearing or gear failure there is usually some metal in the oil.
Post Posted: Sun Sep 12, 2010 1:35 pm
i have changed the oil but didn't notice any but didn't really look for it
Users browsing this forum: Google [Bot] and 20 guests
