[ 4 posts ] |
Print view
Previous topic | Next topic
| Author |
Message |
Barnster
Joined: Wed May 12, 2010 1:01 am Posts: 16 Location: Mid North Coast
 Posted: Tue Sep 14, 2010 2:09 am |
Ever since I've bought my SWB 94 Vit,if I'm driving along with the air con on,then come to a gradual complete stop,the revs go right down to 0,then the engine stalls.When the air con is off,there isn't a problen at all.Does anyone have any suggestion what might be causing this problem.Thanks!
SuziBlu
Joined: Mon Sep 14, 2009 11:30 pm Posts: 4268 Location: Eyre Peninsula
 Posted: Tue Sep 14, 2010 2:11 am |
If you hold revs, as in by the throttle, does it still stall, or is it just when you let it do its own thing.
If its the latter, sounds like the carb is not adjusting to the load, can you turn the lights on and get any form of engine response, extra revs,?
_________________ Bad decisions make good stories.
BlueSuzy
 Posted: Tue Sep 14, 2010 2:13 am |
Is there a wire detatched off the aircon compressor? Sounds like a load signal wire is not working or missing.
The Load wire will make the idle rise alittle for when the aircon compressor is running, so it doesnt stall or lower revs. Same with the power steering pump.
joeblow
Joined: Sat May 10, 2008 11:30 pm Posts: 3273 Location: melbourne
 Posted: Tue Sep 14, 2010 2:25 am |
on the firewall near the brake booster will be a small solenoid with two vaccum hoses and wires going into it. this is the idle up for the aircon. check the wires are ok, lines are ok and the filter (if fitted) is ok. if that is fine have a look at the adjustment of the 'dash pot' that sits on the side of the carby and actuates throttle movement.
_________________ builder of custom road legal zooks......and stuff.
[ 4 posts ] |
Users browsing this forum: Google [Bot] and 405 guests
