It is currently Sun Nov 01, 2026 3:31 am
Post Posted: Thu Aug 26, 2010 9:21 am
Hey guys i havea sked this question though it was some time ago now.
When i got my 99 Jimny it had a noise coming from the front of the car around the wheels/diffs/hubs. The thing is it only comes when i take off straight after starting the car (i.e, not waiting a second or 5), and also when i hit really bumpy road/roads ( tends to happen at this one spot on the way to work everyday).
Now i can make the noise go away by completing stopping forward momentum and when i do the noise slowly whirrs down and then clunks as if a gear or something is falling into place.
If anyone has ever heard of this i would be greatly appreciative, last time they replaced the solinoid for something and it worked...for about a week.
The second problem is also totally random, but when it happens if i let the revs off even the slightest amount of revs off the car seems to lose its power, but when i just slightly touch the acc. the car kicks back into life. Totally annoing.
Anyone?
Mitch.
Mitch.
Post Posted: Thu Aug 26, 2010 9:28 am
Out of interest, next time it happens apply a bit of pressure on the transfer lever as you were putting it into 4h, not in to 4 but a bit of pressure, mine makes a bit of a "whirring metallic noise" usually after being in 4wd though and this stops it.
Geoff
Post Posted: Thu Aug 26, 2010 9:31 am
Thanks heaps, i'll give that a try. Yeah i wouldn't ahve a clue what it is aye, it is like the hubs are trying to lock or something like that. Wierd.
Mitch.
Mitch.
Post Posted: Thu Aug 26, 2010 10:02 am
Anyone?
Mitch.
not really knowing the jimny's, but that could be the crank angle sensor that is known to fail.
Post Posted: Fri Aug 27, 2010 11:51 am
Yeah i thought of that too thanks atari but not knowing jack i wasn't srue it could randomly just start occuring after already travelling 50kms straight. Next time i take it in for a service i'll demand satisfaction. :?
Mitch.
Mitch.
Post Posted: Fri Aug 27, 2010 11:54 am
Mitch.
I think they suffer from heat soak
Post Posted: Fri Aug 27, 2010 9:21 pm
Mitch.
Bingo!! :P
Will be the crank or cam angle sensor, from my experience it will be the hardest to get to as it will have less air flow..
Post Posted: Mon Sep 06, 2010 8:59 pm
so can you detail the fix for the crank sensor sounds like what mine does its like the engine cuts out but the ignition lights dont light up like theres a fuel block ?/
Post Posted: Mon Sep 06, 2010 9:21 pm
Crank sensor is at the back drivers side of the head. dead easy to replace. it causes the engine to cut out when it gets hot under the bonnet .
Post Posted: Tue Sep 07, 2010 9:35 am
Does it keep running?? How many Km's??
Post Posted: Tue Sep 07, 2010 9:05 pm
yes it keeps running no misfire when it fires back up. 206 000klm had a horrible hiding before i bought it eg had bent front axle diff housing and transfer case was shattered
Post Posted: Wed Sep 08, 2010 3:21 pm
On your whirring noise... check your drive shafts... there is a dust slinger at each end where it goes into the box/diff... these have been known to become loose and give you this type of prob..................
On you 'cutout" prob... mine does simular.. intermittantly
Regards Bill
Post Posted: Wed Sep 15, 2010 12:43 am
We have our 2006 Jimny in at the gearbox shop at the moment. Was making the same noise as you described. Turns out a bearing has failed and the clunk and whirring was the gears bouncing around due to the bearing play.
Post Posted: Wed Sep 22, 2010 9:27 am
Geoff
Mine actually does the same thing, half shifting it into 4h stops it. Anyone know what causes this?
Post Posted: Sat Oct 09, 2010 2:22 am
Yeah well half shifting into 4H rips the guts out of my trans so i think i'll leave it out.
Might try replacing the autohubs with some AVM or old sierra manual hubs.
Mitch.
Mitch.
Post Posted: Sun Nov 07, 2010 9:10 am
Did you end up finding out what was causing the grinding noise?
Users browsing this forum: Google [Bot] and 359 guests
