It is currently Fri Oct 30, 2026 4:27 pm
Post Posted: Thu Sep 16, 2010 9:47 am
Are g16a motors any good for sierra upgrade, or do you need the g16b EFI? g16a have only 6kw more power than standard the 1.3 motor
91Sierra; 2in lift; 2inBL; 6.5s; 31muds;
Post Posted: Thu Sep 16, 2010 9:58 am
then go the EFI :)
My Maruti build, Click WWW
i've had both... the difference between g13a and g16a in power is the same as the difference between g16a and g16b... its not on paper, but it feels that way.
g16a is just fine as a conversion and is cheaper by far... and you can always change to g16b down the track as the bottom end is the same except for pistons (so if you go g16a put a set of g16b pistons in when you rebuild it).
personally g16b is far superior though, and i'd recommend saving up and doing it outright.
Post Posted: Thu Sep 16, 2010 10:00 am
oh and look at the torque figures, as thats where the 1.6 EFI shines.
Post Posted: Thu Sep 16, 2010 10:04 am
You can pick up a baleno g16b long motor cheaply.
Whack the 1.3 head and manifolds on and slight changes. A cheap mod for good power (about $300 for adapter plate and a few bits and pieces).
Keep an eye out for a high km vitara 1.6 efi and yoink the head, intake manifold, ecu and loom etc. Reco the head, then fit it later.
Then just get a g16b head gasket, fuel pump, extractors to suit when ready.
Probably the easiest way to convert a DD to 1.6 efi, and it wont cost too much.
Spending $100 more to it this way, and if you decide you cbf doing the efi after adding the 1.6, you just saved yourself some coin and a lot of work.
Vehicle: SJ80, SE416
Post Posted: Fri Sep 17, 2010 1:11 am
I thought the figure was about 12.5kW, but there is a big torque difference between the G16 and G13. That is where the difference lies.
Post Posted: Fri Sep 17, 2010 1:25 am
On redbook the figures read 49kw for 1.3 and 55kw for 1.6. Does anyone know if this is correct
Post Posted: Fri Sep 17, 2010 1:45 am
sounds about right for a carb 1.6
Post Posted: Fri Sep 17, 2010 1:50 am
When I was looking into donks, I found 48kw and 100nm for the 1.3l, 60kw and 123nm for the carb 1.6l and 71kw with 133nm for tyhe 1.6l EFI
Seems to be a lot of varying values.
Post Posted: Fri Sep 17, 2010 2:47 am
That is correct, because the G16 has a longer stroke, it generates more torque but can not rev as high.
The difference in power and torque between the 16A and 16B (1.6 efi), isn't exactly from the efi, its from the higher compression ratio.
Post Posted: Fri Sep 17, 2010 2:58 am
my g16 carb motor revved past 6k no problems :wink:
Post Posted: Fri Sep 17, 2010 6:06 am
revved - past tense =)
Post Posted: Fri Sep 17, 2010 6:13 am
Mine revvvs past 6 grand. not very often though!
Post Posted: Fri Sep 17, 2010 6:17 am
it still would no worries however a few other bits are missing. :wink:
Post Posted: Fri Sep 17, 2010 8:03 am
You do not need the insane revs of the 1.3 to do the same, and better, with a 1.6l.
But, a 1.6l does rev very well.
Vehicle: '94 suzuki maruti
Post Posted: Fri Sep 17, 2010 9:03 am
i had my 1.3 over 7 once... didnt sound pretty, especially with the hole in the exhaust. but i rekon it ran heaps better afterwards :wink:
Post Posted: Fri Sep 17, 2010 9:43 am
lol yep, bin there, dun that, an, yes, most definitely better.
Users browsing this forum: No registered users and 349 guests
