It is currently Sat Oct 31, 2026 8:24 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page 1, 2  Next
Post Posted: Mon Sep 27, 2010 11:21 am
im about to airlock the front of the vitara. im after advice. Im thinking of building a bash plate to cover the diff from rock damage. Will this solve the problem. Its getting fitted next week and times running out on finding a GVsteel one.
Post Posted: Mon Sep 27, 2010 11:25 am
rock damage is the least of your worries with the alloy front diff, it's mainly the rear pinion mount that causes the failures. you can build a collar that braces the pinion mount.
have a read thru this thread for some ideas http://bbs.zuwharrie.com/content/topic,100689.0.html
Post Posted: Mon Sep 27, 2010 11:26 am
It's not an impact thing, it's the diff twisting under load, no fix apart form Gv steel..
locker will only make it worse..
Post Posted: Mon Sep 27, 2010 11:29 am
suzifour offered me one, but I'd already bought one
http://www.suzukiwreckers.com.au/
found mine thru on line parts locators
Post Posted: Mon Sep 27, 2010 11:33 am
http://www.1300wrecker.com.au/Online.aspx
http://www.all4wdspares.com.au/
http://www.exjap.com.au/?id=contact
http://www.eautoparts.com.au/partsreqlist.aspx
http://www.gympiewreckers.com.au/partlocator.php
http://www.findapart.com.au/suzuki_parts.php
Post Posted: Mon Sep 27, 2010 11:34 am
Ill need to join so i can open forum site
Post Posted: Mon Sep 27, 2010 11:36 am
i'd get a steel diff before fitting the locker, when the alloy does explode it might damage your air locker.
Post Posted: Mon Sep 27, 2010 11:38 am
Ill ring every wrecker tomorrow morning. Is there a year model or part number i need .
Post Posted: Mon Sep 27, 2010 11:39 am
Got mine from
Maryborough Auto Wreckers
690 Kent St, Maryborough, QLD 4650
Fraser Coast, Maryborough QLD, Wide Bay
p: (07) 4122 4277
Was cheaper,
even with delivery costs to Melbourne, than buying a local one.
Doubt they would have another, but worth asking
Post Posted: Mon Sep 27, 2010 11:41 am
Must be a manual, as auto GV is alloy too, I think.
Mine was from a 98 GV Manual.
Post Posted: Mon Sep 27, 2010 11:44 am
being a 1.6 you will be able to use either style from a manual V6 GV, just make sure you get the pinion mount with it if it is the later one.
there are a few thread floating around here with pics of the 2 types of pinion mounts, they changed pinion mount slightly in the start of 99 or late 98.
I suggested this to Arb and he seems to think its not gonna break once its locked. Explaining its from diff exploding from wheel spinning flat out and when it hits ground it breaks. And this shouldnt happened once locked.
But i cant sleep so i better just get the steel one. Too many pennys to throw down the drain
Post Posted: Mon Sep 27, 2010 11:46 am
Christover, i'm not sure if you've seen these photo's around the traps but they might give you another idea. the "collar" would work better with the sierra carrier, where as the "strap" would work if you were running the vitara carrier.
i missed this update, here are a couple of pics showing the early & late mounts.
late model
early model
this link shows how much the sump on the SV420 (2.0L) needed to be adjusted to get the late model pinion mount to work, i'm not sure how much clearance there is on the 1.6 SE416 vitara's
http://auszookers.com/index.php?name=Fo ... 639#128639
from this thread http://auszookers.com/index.php?name=Fo ... ic&t=12677
EDIT: the 1.6l vitara does not need the speed dent in the sump to fit the later GV mount in the 2nd to last link
Post Posted: Mon Sep 27, 2010 11:48 am
SUZIFOUR had the later model, and were happy to throw in the mount with it.
Think it was 450 + delivery, but not too sure
Post Posted: Mon Sep 27, 2010 12:02 pm
I should have said manual V6 GVs
Post Posted: Mon Sep 27, 2010 12:41 pm
So which model gv front diff would bolt straight into a 1.6 vit?
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Mon Sep 27, 2010 12:44 pm
either of the manual GV steel diffs will work in the 1.6 going by what Darkhorse has just done.
http://auszookers.com/index.php?name=Fo ... &start=210
later model GV pinion mount.
Post Posted: Mon Sep 27, 2010 10:58 pm
ive found a steely from 04 Grand vitara. Is this going to do the job??
Post Posted: Tue Sep 28, 2010 1:11 am
Give them the nod to send it? Comes with centre. Will arb fit this? im assuming they pull the old diff apart so they can swap it them around
Post Posted: Tue Sep 28, 2010 6:50 am
With yours being a 1.6 it should bolt in just make sure its from a manual GV
Post Posted: Tue Sep 28, 2010 6:51 am
Yes they will need to put your gears into the new diff
Post Posted: Tue Sep 28, 2010 10:51 am
im also needing to change gear ratio for big tyres. Is this the time to do it or is that done in the gearbox
Post Posted: Tue Sep 28, 2010 10:56 am
being a 1.6 you don't have any real options for diff gears & transfer gears will only reduce low range.
Post Posted: Tue Sep 28, 2010 11:48 am
Is yours carbie or efi? if it's efi you will aready have 5.12 diff gears however if yours is a carbie jobbie then track down some 5.12 diff gears that should help out some what with bigger tyres :wink:
Post Posted: Tue Sep 28, 2010 12:21 pm
Mine has a carbie. Which model can these 5.12 be sourced from. Not sure whats in the 04 gv diff ill be getting?
Post Posted: Tue Sep 28, 2010 12:24 pm
You can find them in auto and manual efi 1.6 vitaras and the the gv diff will be 4.3 or 4.6 :?
Post Posted: Tue Sep 28, 2010 12:26 pm
gv will be a 4.3 :wink:
Post Posted: Tue Sep 28, 2010 12:39 pm
Seen a few around getting wrecked. How much should i expept to coff up. This is starting to blow the buget but its gonna be worth it :wink:
Post Posted: Tue Sep 28, 2010 12:48 pm
I sold a rear center for $70 a few months back and now that the one in my car is on its way out i got a price on another one $430 8O
I sold a front one for $40
Post Posted: Tue Sep 28, 2010 12:58 pm
what ratio is in carbie model? If i get locker fitted in new diff ect. Can i replace the gear ratio later on? Or will the airlocker model change?
Users browsing this forum: No registered users and 80 guests
