It is currently Sat Oct 31, 2026 2:59 am
Post Posted: Wed Sep 29, 2010 9:55 am
ok, im a self confessed idiot in regards to all thing electrical.
right now im wiring in my uhf. the wire supplied is to short to reach the battery.
its got a 3amp fuse on it.
i bought some dick smith 'automotive wire' today, its a little thicker and on the sheath is has '15a' printed on it.
does this mean this wire will conduct 15 amps??
if so, will that just continue to blow the fuse on the existing wiring loom? or is this ok to use??
sorry if i made you dumber after reading this, i just dont want to fuck my brand new uhf :D haha.
thanks in advance electrical gurus!!
might just be the slowest build on the forum...
Post Posted: Wed Sep 29, 2010 9:59 am
the 15amp is the max you can draw on the cable but doesnt mean you draw that with that cable
It means the wire is capable of conducting 15 amps...
But the wire will only conduct the current that the uhf draws from it...
You want the wire to be rated higher than the fuse protecting it, otherwise if there's a short the wiring will heat up and catch fire before the fuse blows.
I want my old sig back :(
Post Posted: Wed Sep 29, 2010 10:02 am
you are too good to me gentlemen!
much appreciated :)
thanks for ya help!!
Post Posted: Wed Sep 29, 2010 10:04 am
the 3amp fuse will blow long before the 15 amp wire burns, all will be ok if you use the 3amp fuse and holder.
Post Posted: Wed Sep 29, 2010 10:11 am
get power off the radio wiring or somewhere closer, if you plan on getting power and earth direct from the battery you need a fuse on BOTH power and earth AT THE BATTERY.
Post Posted: Wed Sep 29, 2010 10:14 am
good idea, ill just tap into the head units power and earth and that should be ok yes??
thatll save running anymore wires off the battery
Post Posted: Wed Sep 29, 2010 10:18 am
personally id try pull power from before a fuse then fuse your own new cable just because then if one thing fucks out everything doesnt die
Post Posted: Wed Sep 29, 2010 10:27 am
cigarette lighter is always a good point to get power..
Vehicle: jimny
Post Posted: Wed Sep 29, 2010 10:28 am
It's good to see your having a go mate and asking the questions before burning your car down. Auto wiring is pretty simple and with enough practice you will be a guru
Post Posted: Wed Sep 29, 2010 10:49 am
:D hahaha
the night is not over, the car can still burn down :P
*gets the hose, puts it arms reach from car*
edit - will this need constant trickle of power for memory??
Post Posted: Wed Sep 29, 2010 10:57 am
no
Post Posted: Wed Sep 29, 2010 11:59 am
What's the purpose of fusing the earth - under what circumstances will that fuse blow?
Standard practice dictates the fuse should ALWAYS be in the hot line, never the return.
Post Posted: Wed Sep 29, 2010 12:11 pm
ok, so what is the 'dome' fuse?? EDIT its the interior light...
i got the uhf working fine, but when i plugged the cd player loom back in the dome fuse blew.
i have tapped into the earth and the power from the head unit (yellow)
im thinking i shoul have done acces (red) with the power yes?
red to red... makes sense now
Post Posted: Wed Sep 29, 2010 12:13 pm
yes
Post Posted: Wed Sep 29, 2010 12:30 pm
success :)
who would have thought colour coding would be the key *face palm*
Users browsing this forum: Google [Bot] and 894 guests
