It is currently Sun Nov 01, 2026 12:47 pm
Post Posted: Thu Sep 30, 2010 1:51 pm
HELP me guys i went to check my diff oil on my 1993 leafy and i couldnt loosen the plug?? is there a trick?? is it a reverse thread.... i have a multi sized sump plug remover but i cant get enough purchase on it and then it slips out as it is tapered on the only bit that fits???
what can i do?? :roll:
should i use the vice grips?? drill it??? where can i get replacement plugs??
how do i get the little shit loose?? :x
Post Posted: Thu Sep 30, 2010 2:30 pm
If its like the Vitaras mate the square drive from a 3/8" ratchet fits perfectly. Most of mine loosened off easily with my large breaker bar (and a 1/2" down to 3/8 adapter).
One was a royal prick though cause it was already slightly rounded out. Impact wrench with said 3/8 adapter made short work of that one though.
Moses' SQ625 GV Pig
Post Posted: Thu Sep 30, 2010 3:09 pm
2 of mine were so rounded i just used easy outs takes about 5 min to get them out then XD
Vitara JX 1.6, straight through 2 1/4" exhaust, 2.
Post Posted: Thu Sep 30, 2010 3:15 pm
It's not 3/8" - it's 10mm, and use of a 3/8" adapter or rachet handle is what usually rounds them out
http://cgi.ebay.com/ebaymotors/8mm-10mm-Square-Drain-Fill-Plug-Sockets-Ford-Volvo-Saab-_W0QQcmdZViewItemQQhashZitem563fae0f70QQitemZ370435559280QQptZMotorsQ5fAutomotiveQ5fTools
This is what you should be using.
Post Posted: Thu Sep 30, 2010 4:43 pm
Vice grips should do it, if its already rooted.
Mine was rounded, tried everything. Vice grips worked a treat.
Just do it back up afterwards and dont worry about it until you change diff oil again.
Post Posted: Thu Sep 30, 2010 7:05 pm
give it a good hit with a hammer to free it up.
Post Posted: Thu Sep 30, 2010 8:42 pm
I agree 8)
And if that don't work Dave07's option defiantely will :wink:
Post Posted: Fri Oct 01, 2010 10:19 am
Hey thanks fordem, i've been looking everywhere localy for one of these adaptors, had no luck. I just ordered one from these guys, thanks to your post. :D
Post Posted: Fri Oct 01, 2010 10:27 am
Haha love the sellers name. "You've been banging on your pots again havent you. I told you, if you keep on doing it, you wont have any pots left!"
Vehicle: SJ80
Post Posted: Sat Oct 02, 2010 2:41 am
I always wack mine with a hammer before trying to undo them. Helps.
Post Posted: Sat Oct 02, 2010 10:15 pm
thanks guys..... going to have a fiddle tomorrow .... pending dry conditions as its almost flooded here and 'Bazooka Leone' lives on the street to dave07... what exactly is an easy out??
excuse the newb ignorance
Post Posted: Sat Oct 02, 2010 10:41 pm
Cheers for the ebay link fordem - Good to know you can get the proper tool for it. I'd looked around locally back when I needed it and everyone just wanted to sell me those useless multi fit tools.
the wizard - ez outs are a reverse threaded tapered screw. Do a google on em to see how they work. The force from you doing it up (in a counter clockwise motion) gets to the point where it undoes whatever it is you are drilling into instead.
Moses' SQ625 GV Pig
Post Posted: Sat Oct 02, 2010 11:44 pm
oh, ive seen those.... had no idea what they were called though,
thanks guys for your help, ill give the hammer a go if it doesnt work, ill go to the local auto parts joint (peps auto) and see if i can get a hold of some 'ez outs' does anyone know where to find a replacement plug for it??
Post Posted: Sun Oct 03, 2010 12:08 am
Peps Auto should have em :wink: If not just go to a bolts supply place and get a similar beast. I got some allen head plugs for mine.
Post Posted: Tue Oct 12, 2010 7:32 am
x2
Post Posted: Tue Oct 12, 2010 8:13 am
If it's super stuck, cold chisel it out ;)
Then buy a new plug :P
helloo
Post Posted: Tue Oct 12, 2010 8:17 am
X2 sharp tap.
when you put a new one in or that one back use copper eze on the thead or teflon tape sort of works too
Vehicle: 94 Vitara LWB G16b
Post Posted: Tue Oct 12, 2010 8:40 am
I ened up going to weld a bolt on to mine, but the heat from the welder freed it up, so you could try a little heat to loosen it?
94 Vitara LWB G16b
Post Posted: Mon Oct 25, 2010 10:13 am
Here's an example of someone's solution. I guess you could tighten and undo that with the jack crank handle?
Post Posted: Mon Nov 08, 2010 12:19 am
x2
yay my sockets FINALLY arrived.... took nearly a month from the US.
Users browsing this forum: No registered users and 393 guests
