It is currently Sat Oct 31, 2026 3:00 am
Post Posted: Sun Sep 26, 2010 5:36 am
hey all just wondering if there is somebody on the coast to help me get my 91 sj70 soft top runnin right (please)
Post Posted: Sun Sep 26, 2010 5:58 am
Tell us what the problem is mate.
My Maruti build, Click WWW
Post Posted: Sun Sep 26, 2010 6:30 am
ive tried every thing from changing carbys to replacing all hoses and she still runs with a slight miss and every now and then it stalls for no reason
mud oh gloriuos mud
Post Posted: Sun Sep 26, 2010 7:39 am
want33s
pm him and talk about this, he will sort things out.
Post Posted: Sun Sep 26, 2010 8:06 am
i spoke to jas he is betterwith efi he is also the bloke i bought te new carby off
mud oh gloriuos mud
Post Posted: Sun Sep 26, 2010 8:16 am
i know sfa about carbys so i cant help u man. have you checked the dizzy and leads ect?
Post Posted: Sun Sep 26, 2010 8:21 am
fuel pump aswell ?
Vehicle: Sierra
Post Posted: Sun Sep 26, 2010 8:52 am
Plugs and points, check timing advance too.
Post Posted: Sun Sep 26, 2010 9:24 am
check for shit in the tank i saw a gum nut do the same thing, gets sucked in engine stalls nut floats away to get sucked in again later
Post Posted: Sun Sep 26, 2010 9:26 am
:? good luck changing them.. :P
Post Posted: Sun Sep 26, 2010 9:45 am
:rofl: recon ay.
Post Posted: Sun Sep 26, 2010 9:50 am
What is the carby. ?
Post Posted: Sun Sep 26, 2010 10:00 am
its a stock carby the only two things i havnt properly checked r the dizzy and fuel pump ,the dizzy does not have points so i dont know how to check lt out , i also havnt checked fuel tank is there an easy way to clean it out is there a drain plug and thank you all for helping me
mud oh gloriuos mud
Post Posted: Sun Sep 26, 2010 10:02 am
im thinking about buying steak knifes toyota carby or a webber which is better
mud oh gloriuos mud
Post Posted: Sun Sep 26, 2010 11:39 am
i would check everything else before you buy a another carby, make sure that the carby really is the problem.
Post Posted: Sun Sep 26, 2010 12:01 pm
x2..
Post Posted: Sun Sep 26, 2010 12:28 pm
Sounds to me like its not the carby, you have changed it and no difference.
The fuel filter, change it, when its night, real dark, start her up and look at the motor, see if you can see any sparks. Have a good look at the dizzy cap, close look, check the contacts, and also for a crack, may only be super small, but that is all thats needed.
Get a can of start ya basted, start her up, spray around the carby, close, if there is a minor vacuum leak, it will suck this in and revs will increase, all around.
Post Posted: Mon Sep 27, 2010 6:05 pm
Not sure if this will help, but I had a similar problem with my SJ50. I changed everything related to the ignition, took the tank out and cleaned it, put on new filters etc. and found out eventually that one of the water hose connections to the carby was corroded and had a slight leak, and when it got up to normal working temp. it would stall and miss! I fixed that and solved the problem .....
Post Posted: Tue Oct 05, 2010 8:10 am
OK IVE TRIED EVERY THING NOW ITS ALSO COUGHING AND SPUTURRING LIKE A BITCH AND JERKING LIKE AN 18 YR OLD WATCHING PORN I NOW THINK ITS TIME TO FIND A MACHANIC ANYONE KNOW A GOOD MECH ON THE COAST WHO KNOWS ABOUT SUZUKIS
mud oh gloriuos mud
Post Posted: Tue Oct 05, 2010 8:26 am
have you checked if the head gasket or carby gasket have any air leaks
Post Posted: Tue Oct 05, 2010 8:30 am
head gasket no how hard is it to change engines i have the chance to buy a barina engine cheap
mud oh gloriuos mud
Post Posted: Tue Oct 05, 2010 8:45 am
dont know much but im guessing new engine mouts and and barina is front wheel drive so i dont know if a sierra box will fit to a barina engine
Post Posted: Tue Oct 05, 2010 9:36 am
Barina is G13 but you'll have to swap sump and pickup, engine mounts, manifolds and possibly pulleys if it doesn't come with an alternator.
Post Posted: Tue Oct 05, 2010 9:44 am
for my barina swap i had to change the following:
sump and oil pickup
inlet and exhaust manifolds
alternator bracket
alternator pulley (also had to make a spacer for the pulley)
water pump
fuel pump
cam
distributor
engine mounts
Also a rocker but that is because i broke one... The swap wasn't too hard, took a day to get the barina engine out, my engine out, swap the stuff over and get the barina engine in my car. Took another day to get it all going and tuning and stuff though.
Post Posted: Tue Oct 05, 2010 9:50 am
might wait 4 a vitara or sierra motor might b easier
mud oh gloriuos mud
Post Posted: Tue Oct 05, 2010 9:54 am
to each their own but I paid $160 for a full barina motor that only had 57000k's on the clock and now the wreckers are even cheaper...
Post Posted: Tue Oct 05, 2010 9:56 am
Get a mechanic to have a look at it... Doesn't have to be a zook specialist, just any mechanic... Its probably something fairly simple...
I want my old sig back :(
Post Posted: Tue Oct 05, 2010 10:39 am
thanks guys
mud oh gloriuos mud
Post Posted: Wed Oct 06, 2010 4:06 am
where abouts on the coast are you?
Post Posted: Wed Oct 06, 2010 5:39 am
wurtulla
mud oh gloriuos mud
Users browsing this forum: Google [Bot] and 905 guests
