It is currently Sat Oct 31, 2026 4:42 pm
Post Posted: Fri Oct 08, 2010 10:36 am
ok, i can go and get a vit fuel tank which would go pretty sweet in my lwb because im told i need some special fuel thingo for my TBI. will a tank out a an 89 vit have the special fuel gadget? And what does the gadget do?
cheers Josh :D
Post Posted: Fri Oct 08, 2010 10:38 am
:P What's the gadget?? :P
Post Posted: Fri Oct 08, 2010 10:40 am
stek you know im very lost! tech please before this turns into dribble :lol:
Post Posted: Fri Oct 08, 2010 10:41 am
lift pump is it?
Post Posted: Fri Oct 08, 2010 10:44 am
lift pump is it?
Not with a vit efi tank, no lift pump needed, has a swirl put built in with a h/pressure pump, TBI should have a reg on it.
Lift pump's are needed for surge tank's..
:P Is that techy?? :P
Post Posted: Fri Oct 08, 2010 11:13 am
ok, so will an 89 vit tank have that?
Post Posted: Fri Oct 08, 2010 11:16 am
im lost??? :lol: :lol: do you need a tank from a efi model with pump in it or a coily tank or are you getting at somethin else man?
Post Posted: Fri Oct 08, 2010 11:29 am
Only if it's efi, the carb one's are diffrent..
Post Posted: Fri Oct 08, 2010 11:33 am
i'll have a crack :P
you heard the vit tank will fit your lwb with mount mods :wink:
the efi tank has the sender you need to run fuel injection :wink:
not sure if it will work with tbi :| .. i think not. a suzuki tbi guru can jump in but i think they run a lower pressure than mpfi. somewhere around lift pump pressure?
Post Posted: Fri Oct 08, 2010 11:34 am
if someone ran up to me and punched me in the mouth and told me it was a vit tank i'd believe them about now.....
ok so, i've been told that to run tbi you need to use a different tank. because of the fancy bit's inside of them (still not sure what any of the fancy bits are just know i need them)
im not that worried about what the fancy bit's do i just need to know if an 89 vit tank will be waht i need..............
Post Posted: Fri Oct 08, 2010 11:37 am
mr green thanks :D
but like stek said i think that there is a built in fuel regulator + i've been told on many occasions that i need a high pressure VL fuel pump.... i think ill be safe with the vit tank and it's junk....
Post Posted: Fri Oct 08, 2010 11:40 am
elgoogle says no dice.... it's going to be carby.....
Post Posted: Fri Oct 08, 2010 11:42 am
ok then. the fancy bits your talking about are the swirl pot, pressure pump, return hose . a 89 vit will only have it if its a lwb. shortys didn't see efi till 94.
Post Posted: Fri Oct 08, 2010 11:47 am
so a pressure pump is a fuel pump? if i got a vit tank and it was efi i wouldn't need to buy another fuel pump?
Post Posted: Fri Oct 08, 2010 11:52 am
yep. theats right. a lot neater and quieter than the vl pump setup. just hard to come by. i ended up buying a whole lwb vit to get parts including tank. rang around the wreckers and couldn't find a complete tank this side of the big smoke...... but somehow it was easier to drive to gympie to part a car than drive to sydney to pick up a tank :? :lol:
Post Posted: Fri Oct 08, 2010 12:05 pm
then offload the rest of the car to some bloke :lol:
Post Posted: Fri Oct 08, 2010 8:45 pm
haha thanks :D
Post Posted: Fri Oct 08, 2010 9:10 pm
just a thought. why cant fuel pumps from a efi outboard be used? mine self primes
and lifts fuel probably 800mm and the tank would be 3mtr from the pump.
they don't need a swirl pot or return line of any of that sort of flash stuff. they
just need a fuel line, 12v power and cableties to stop it flapping around.
Post Posted: Fri Oct 08, 2010 9:53 pm
the reason you need all this is cause EFI doesnt have a float bowl like a carby does so there is no buffer for times when its not possible to pick fuel up from the tank, IE low tank level and up or down hills or side angles or cornering and so on, which leads to stutters and lean outs and bad stuff
so you either need an efi tank like out of a vit or coily that has the pump inside it picking up fuel from a well in the bottom of the tank thats designed to stop the starvation issue or run a low pressure pump from a carby tank into a surge tank that then feeds a high pressure pump for the engine, the surge tank by design then always has fuel at the pickup at the bottom and is big enough to have a buffer when no fuel is being suplied from teh tank
Post Posted: Fri Oct 08, 2010 10:40 pm
I used to run TBI with a VL Bosch pump and now run MPFI with the same pump.
I run a standard Sierra tank with a facet lift pump to a surge tank then the Bosch to the engine.
31Zook:
Get a coily tank and fit an EFI Vitara pump to it
OR
Get a post 94 Vitara SWB tank and fit it complete.
OR
Get a Vitara LWB(any year) tank and fit that.
Post Posted: Fri Oct 08, 2010 11:06 pm
im thinking for the whole looking stock thing ill go a vit efi tank, sounds more simple the rest of the options
thanks royce for explaining what all the gadgets do :D
Post Posted: Fri Oct 08, 2010 11:21 pm
The most "stock" looking setup would be a coily tank with a Vit pump fitted.
It is the easiest too... IF you can find a coily tank.
Post Posted: Sat Oct 09, 2010 12:42 am
yeah, but for the extra fuel i can carry i think it would be worth it.....
Post Posted: Sat Oct 09, 2010 12:47 am
Vit SWB efi tank is the same capacity as the sierra I think :?
Bubble burst :lol:
The LWB tank is 55L, and the SV420/620 is 60ish.
Post Posted: Sat Oct 09, 2010 1:18 am
ahh shut up pete, thanks :D
Post Posted: Sat Oct 09, 2010 1:23 am
Bubble burst :lol:
:P Wrong!!!! :P
Users browsing this forum: Google [Bot] and 102 guests
