It is currently Mon Nov 02, 2026 6:44 am
Post Posted: Mon Oct 11, 2010 7:46 am
hey i have a g16a bolted to a 1.3 gearbox with adapter plate
i havea a 1.3 starter motor as i didnt have time to fine a 1.6 starter motor
can ny one tell me or show me were you have to grind for it to fit.
heres a pic
much appreciated
Aaron
Post Posted: Mon Oct 11, 2010 7:49 am
I would personally grind the starter rather then the block.
My Maruti build, Click WWW
Post Posted: Mon Oct 11, 2010 7:50 am
x2 grind the starter motor's housing, did it on mine and works fine :)
Post Posted: Mon Oct 11, 2010 8:01 am
where on the starter do you grind nd how much do you grind off
Aaron
Vehicle: Zookless
Post Posted: Mon Oct 11, 2010 8:13 am
Push the starter motor into position.
Rub it up and down against the engine block.
You should be able to see where it has contacted.
Start grinding...
I have to pull mine out again and grind off some more. It's making a pretty awful noise as the starter disengages :?
Post Posted: Mon Oct 11, 2010 8:14 am
you grind the face of the starter that contacts the block. Do a little bit at a time with a flappa disc and check fitment every few passes with the grinder. Just make sure the starter sits in position properly.
79' LJ80 (sold) :(
95' & 97' sierra (sold)
Stick starter on, see where it's hitting (rubbing) grind a bit, check it, grind more till all is good.
There is no set measurement to take off because I'm guessing no-one would know, It's all suck and see.
Post Posted: Mon Oct 11, 2010 8:15 am
Bwhahahah 3 posts in about 1 min all saying the same thing. :-)
Vehicle: Zookless
Post Posted: Mon Oct 11, 2010 8:16 am
I hope we're not all wrong :P
LOL
Post Posted: Mon Oct 11, 2010 8:17 am
If only I could type faster I would have won. :-)
Post Posted: Mon Oct 11, 2010 8:24 am
ok thanks guys ill wll try it tomorrow. hope you's are right :lol:
Post Posted: Mon Oct 11, 2010 8:46 am
If it all goes to shit I'll delete my posts and blame all the others. LOL
Post Posted: Mon Oct 11, 2010 8:56 am
8O
:lol:
Post Posted: Mon Oct 11, 2010 9:23 am
your a beast how'd you go
Post Posted: Mon Oct 11, 2010 9:31 am
umm shit wasnt sitting straight so i got to do some grinding :D
Post Posted: Mon Oct 11, 2010 10:32 am
you were lucky to be the sperm to win the race to the egg all those years ago..... I wouldn't get high hopes of ever winning anything else bruce!!!
:P :thefinger: :P
Users browsing this forum: Google [Bot] and 65 guests
