It is currently Sun Nov 01, 2026 2:26 am
Post Posted: Tue Oct 12, 2010 5:52 am
ohk so theres the 4 wires to the ignition, black with yellow stripe, black with white stripe, white with black stripe, and plane white, does anybody know which is which as i need to hotwire an old sierra as the key is lost and i need to check if the motor still runs ok before i pull it out and swap it for mine
cheers in advance
Post Posted: Tue Oct 12, 2010 5:59 am
just pull the back out of the ignition barrel and use a screwdriver.
Post Posted: Tue Oct 12, 2010 6:04 am
cheers shep, just took it out then, will hook a battery up to her tomoz and test it out
Post Posted: Tue Oct 12, 2010 6:06 am
I don't have a wiring diagram here but it would be fairly simple to work out.
Strip back the wires and find out which one has 12V on it.
Touch the 12V to each wire in turn.
One will turn on the radio etc, this is ACC.
One will turn on the ignition (dash lights will come on). This is IGN.
One will turn the starter motor. This is START.
Twist 12V up with IGN to to turn the ignition on, then touch START to them to turn the starter over until it starts...
I want my old sig back :(
Post Posted: Tue Oct 12, 2010 6:07 am
Or do what shep said...
Post Posted: Tue Oct 12, 2010 6:09 am
haha yeah thanks for the info though ben
Post Posted: Tue Oct 12, 2010 7:05 am
yellow and black should be the start cct i think
Post Posted: Tue Oct 12, 2010 7:13 am
this is from memory, likely to be wrong
white is power in (battery)
black yellow is start
black white ign
white black is acc
bottom two could be the other way around too
Post Posted: Tue Oct 12, 2010 7:19 am
The onyl wiring diagram I could find was US spec and the colours were all different...
Post Posted: Tue Oct 12, 2010 7:48 am
yeah same.
cheers for all the help guys
Post Posted: Tue Oct 12, 2010 10:11 am
black white ign
white black is acc
Your memory is good.. :P
Post Posted: Tue Oct 12, 2010 8:44 pm
You do have the owners permision ,yes.. :?: :lol:
I mean you did ask how to Hot Wire a suzuki.. :wink:
Post Posted: Tue Oct 12, 2010 8:57 pm
haha yeah its my spares sierra ive got sitting round the back
Users browsing this forum: No registered users and 120 guests
