It is currently Sun Nov 01, 2026 11:39 am
Post new topic Reply to topic  [ 49 posts ]  Go to page 1, 2  Next
Post Posted: Fri Oct 29, 2010 10:52 pm
Hi all,
I just had to join this forum after searching and searching - I guess I need some expert advice!
I have two problems with my Sierra...
No1.
A VERY high (ear piercing) whine when stationary, out of gear. It goes when you rev past 1100rpm.
No2.
Automatic choke doesn't work and I have no idea how to test it. It runs too slow from cold, so I have to turn the idle screw up, then it warms up and it runs too fast, so obviously I have to turn it down manually again.
So, can anyone help me out?
Thanks for reading and your time is much appreciated ;)
Pommy3D
Post Posted: Sat Oct 30, 2010 12:18 am
For the noise:
check the fan belt tension.
Does the noise go away if you step on the clutch?
Thermo choke: ....Paging Royce....
Post Posted: Sat Oct 30, 2010 12:23 am
ive worn all the choke keys out :) can somebody search it for me :)
start with taking a pic of the top of your carby when the engine is cold with teh air intake removed and then when the engine is warm check the 2 water hoses into the back of the carby are getting hot
Post Posted: Sat Oct 30, 2010 12:36 am
Hi, thanks for the fast reply.
The noise is definitely not the fan belt.
It's like a low pitched whine coming from under the exhaust manifold?
I'll take some video and some pics this arvo, has to be heard!
Thanks guys!
Post Posted: Sat Oct 30, 2010 1:02 am
Exhaust manifold gasket leaking, or hairline crack in Manifold?
Or maybe the bearings in your Turbo have failed?? :twisted:
Post Posted: Sat Oct 30, 2010 6:58 am
Ahhh only just got back and it's dark.
I'll have some pics of the carb and a video of that damn noise in the morning.
Thanks again for the support ;)
Dyslexics of the world, UNTIE!
Post Posted: Sun Oct 31, 2010 1:27 am
had a similar noise on mine took the heat shroud of and the manifold had 2 cracks in it one under neath one on the front both between cylinders 3&4
Vehicle: '92 Sierra
Post Posted: Sun Oct 31, 2010 8:44 pm
Stationary out of gear. So I take it that is in neutral without the clutch depressed? So it goes away with the clutch in? My second zook is making a whining noise (not ear piercing though) in that area with all the above symptoms. I'm guessing maybe the throwout bearing. Maybe someone else could chime in whether the throwout bearing should be spinning in neutral without the clutch depressed. Exhaust leak could make the noise but obviously whether it's in gear or stationary should make no difference.
Post Posted: Sun Oct 31, 2010 9:10 pm
Post Posted: Mon Nov 01, 2010 12:16 am
Post Posted: Mon Nov 01, 2010 12:58 am
http://s103.photobucket.com/albums/m143 ... aNoise.mp4
How about that?
Post Posted: Mon Nov 01, 2010 1:06 am
Ooooh... That's a weird one but it sounds to me like possibly a harmonic vibration.
Check the front pulley is tight for starters. Check every bolt you can find come to think of it.
Whereabouts are you ??
Post Posted: Mon Nov 01, 2010 1:09 am
Ok - I'll get onto that front pulley right away!
Thanks ;)
Vehicle: '92 Sierra
Post Posted: Mon Nov 01, 2010 1:28 am
hehe yep that isn't your throwout bearing. Sounds like a tuning fork on roids. Rev change changes the frequency so you can't hear it. I wonder if the metal jacket around the exhaust manifold could do that.
Post Posted: Mon Nov 01, 2010 1:34 am
Could be a thin tin shield vibrating such as the exhaust heat shield. Could also be electrical noise from the alternator as well. Easy way to check this would be to simply remove the fan belt and start the engine
Lil Foot!
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Nov 01, 2010 1:52 am
It actually sounds like a whistle to me.. all your hoses attached?
I could be way off my hearing is not the best anyway.
Post Posted: Mon Nov 01, 2010 2:03 am
Hi,
Pulley tight - everything tight!
Heat shield secure.
No hoses loose.
Seems to be coming from the front undeer the belt cover!?
Arrrgh?!
Oh, it gets better when it's warmed up (indicates metal to me again).
Post Posted: Mon Nov 01, 2010 2:07 am
Where on the coast are you ?
Post Posted: Mon Nov 01, 2010 2:12 am
Buderim mate ;)
It's going to get registered this arvo, so i'll have plates on it very soon!
Post Posted: Mon Nov 01, 2010 2:14 am
Thats loud enuff for my deaf ears to hear.
Mine did a similar thing once.
Improper,missing or worn spacer rubber bit behind timing cover, can push the cover onto the cam pulley..
Is it up near front?
carefully pull n push top of timing belt cover, see if it hits.
watch hands and fingers near spinning fan etc
Post Posted: Mon Nov 01, 2010 2:23 am
pommy3d wrote:
Buderim mate ;)
PM me your number and I'll come and have a look.
Post Posted: Mon Nov 01, 2010 6:57 am
want33s wrote:
pommy3d wrote:
Buderim mate ;)
Hi - that's very generous of you - but i'm embarrassed to say I can't really pay you - not even in beers at the moment :(
I'll take the cover off as the previous post suggested and see if that stops it - it seems in the video that it gets louder around that point. You can't tell when you are in front of it where it's coming from.
I'll post back tomorrow and let you know what happened!
Great forum by the way - just great!
Post Posted: Mon Nov 01, 2010 7:24 am
I have seen dry seal's make that noise...
But that was a new seal fitted with out lube, doubt an old one would dry out enough to make that noise tho..
Post Posted: Mon Nov 01, 2010 8:55 am
have you tried using a long screwdriver or similiar as a stethoscope and listening for a dry bearing.. I would try the alternator or water pump as first candidates..
do the little heater/ water hoses on the carby get warm when the car has run for a while??
is the choke butterfly open when you look down the carby throat??
Post Posted: Mon Nov 01, 2010 9:21 am
do me a favour , and when the noise occurs , stand at the right hand guard , grab the oil cap and tappet cover and pull , see if it goes away , im betting its a collapsed engine mount and the metal cover on the mount is making that noise. hence when you rev the engine its lifting enough off the cover to stop the noise.
Post Posted: Mon Nov 01, 2010 9:24 am
ohh i have also heard this noise another place before , and it was a couple of loose bolts in the l/h mount where it mounts to the block , so best to check all the bolts there and the other thing i suggested
Post Posted: Mon Nov 01, 2010 11:21 pm
" I would try the alternator or water pump as first candidates.."
I took the fan belt off and the noise is there still.
"do the little heater/ water hoses on the carby get warm when the car has run for a while??"
The two poking out of the back get warm after about 2 mins or less of running.
"Is the choke butterfly open when you look down the carby throat??'
I'll take that off in a second ;)
"do me a favour , and when the noise occurs , stand at the right hand guard , grab the oil cap and tappet cover and pull , see if it goes away , im betting its a collapsed engine mount and the metal cover on the mount is making that noise. hence when you rev the engine its lifting enough off the cover to stop the noise."
Nope, makes no diffeernce unfortunately :(
"ohh i have also heard this noise another place before , and it was a couple of loose bolts in the l/h mount where it mounts to the block , so best to check all the bolts there and the other thing i suggested"
Not that either.... its VERY hard to pinpoint.
http://i103.photobucket.com/albums/m143 ... s/Carb.jpg
Post Posted: Tue Nov 02, 2010 11:45 pm
Cold carb:
http://i103.photobucket.com/albums/m143 ... s/Cold.jpg
After 2 mins running:
http://i103.photobucket.com/albums/m143 ... r2mins.jpg
From cold start it runs, barely and juddering at 500rpm, after 10 mins it idles at 1000rpm perfectly.
Post Posted: Tue Nov 02, 2010 11:51 pm
Good news, your choke works, its just a little off
At thte back of your photos, see the metal fan shaped gear thingo that works agaisnt teh white plastic gear?, follow the metal bit along its linkages and down and you see a threaded adjuster going through it, accesable from teh passenger side, you jsut need to adjust that a bit so the choke flap (flap on top of the carb) closes up a bit more WHEN COLD!!!!
try it cold and see where its at, you might find you need to go some more or if it struggles when you drive you might need a bit less
you can adjsut the cold idle speed independant of that but its a bit harder and better to get this part working better first
Post Posted: Wed Nov 03, 2010 12:16 am
Cheers Royce!
I'll wait for her to cool and give that a shot!
So it should be closed or almost closed?
Thanks ;)
Users browsing this forum: Google [Bot] and 425 guests
