It is currently Sun Nov 01, 2026 9:43 am
Post Posted: Sun Oct 31, 2010 11:33 pm
Hi,
having trouble getting the drums back over the new shoes i just installed. Not sure how anything can be adjusted.
Keep reading about star wheel adjusters but cant see anything like that in there.
Wheel cylinders are fully compressed.
PS its sierra rear drums I am talking about.
Post Posted: Sun Oct 31, 2010 11:39 pm
the lever that the handbrake works off, there is a curved thingy with a sort of serrated edge that jams against another bit, jam a flat screwdriver in there and lever it so the rounded part pushes in towards the backing plate
youll see the shoes move in, then stick your drum on and lightly pump the pedal up, that rounded thing will ratchet back out to adjsut the shoes into place
Post Posted: Sun Oct 31, 2010 11:58 pm
youll have to back off the handbrake adjuster. i udjusted it up when my brakes where getting down
Post Posted: Mon Nov 01, 2010 12:15 am
the handbrake is busted off the right side.
Vehicle: 00 Jimny, 63 Haffy
Post Posted: Mon Nov 01, 2010 1:49 am
royce and you are talking about the "star wheel" auto adjusters, you can release them from the back of the brake though the little hole with a flat screw driver.
The mechanic I took my car to get the RWC, it had been so long since he even worked on a car with drum brakes, he couldnt get them off and so failed them.
Me: did you release the auto adujsters? him: "The what?"
Post Posted: Mon Nov 01, 2010 1:50 am
nah they are a ratchet thing, cant release them from outside
Post Posted: Mon Nov 01, 2010 2:05 am
mine do! there is a little hole on the back of the brakes to do it from.
maybe its different on a wide track?
Post Posted: Mon Nov 01, 2010 2:09 am
even with adjusters backed all the way off they still don't go on. I am resorting to grinding the dicks down on the shoes where they go on the wheel cylinders.
Post Posted: Mon Nov 01, 2010 2:12 am
did you get teh drums machined and do you have the right shoes?
could be the incorrect wheel cyls? pretty sure there are a few different ones of diff sizes
Post Posted: Mon Nov 01, 2010 2:15 am
Thank fuck you drive in Vic and I'm nearly 2000km's away from your dodgy shit.
www.suzukiinfo.com download the FSM and you'll have all the answers.
Post Posted: Mon Nov 01, 2010 2:20 am
found a pic of it: Image
its the elongated hole in the top left of this shot.
Post Posted: Mon Nov 01, 2010 2:23 am
AH!
thank your stars im not heaps not near you too.
I remember doing that same thing (grinding off the extra bit) when I compared them to the ones that came out of the car they were a different shape.
ha!
Post Posted: Mon Nov 01, 2010 2:49 am
AH!
ha!
You guys need to learn to SERVICE your cars.... Not just repair them when they break.
Post Posted: Mon Nov 01, 2010 3:05 am
want33s wrote:
AH!
ha!
What is this 'service' word that you speak of :lol: :lol: Like royce said, did you get the drum machined??
Post Posted: Mon Nov 01, 2010 3:25 am
What would make you possibly think we dont service our cars? Comments like that are asking for a flame war! Ive done major services to mine 3 times in 8 months! I pulled off the whole front of the motor and replaced much of it because the fan pulley was a little wobbly, changed unis in the front drive shaft that were hardly worn.
I don't want to talk to you, no more, you empty-headed animal,
food trough wiper. I fart in your general direction. You mother was a
hamster and your father smelt of elderberries.
Actually, I would have change the cylinder to the correct one too but given the shoes that came out were done the same way and worn very evenly, and I had just spent hundereds of dollars on other parts and I had to get the RWC the next day to make my Vic Roads appointment I did it.
Now go away or I shall taunt you a second time!
Post Posted: Mon Nov 01, 2010 3:33 am
I'm going to get the popcorn, this is going to be good :P :P :P
Post Posted: Mon Nov 01, 2010 3:39 am
Grinding a bullbar or sliders or bumper to make them fit is one thing...
But grinding bits off your brakes 8O
I want my old sig back :(
Post Posted: Mon Nov 01, 2010 3:53 am
can you get me some too rusho
Post Posted: Mon Nov 01, 2010 4:02 am
Service?
Isn't that what you get at a small business?
Post Posted: Mon Nov 01, 2010 4:21 am
You either have the wrong wheel cylinders or brake shoes mate. There are a few different combinations out there.
Grinding down the tabs on the shoe sounds dodgy but personally I don't see an issue with it as long as there is sufficient material left on the tab to properly locate it within the wheel cylinder and the wheel cylinder does not over extend.
Lil Foot!
Post Posted: Mon Nov 01, 2010 4:24 am
and the radius on the shoe still works, you could end up with heaps of shoe not touching the drum
Post Posted: Mon Nov 01, 2010 4:53 am
it was a matter of grind a bees dick off coz all adjusted loose it still wouldn't go on. Now tell me whats better brakes that work well or brakes that dont.
Post Posted: Mon Nov 01, 2010 4:54 am
Yeah, I would not have done it if it was the wrong shoe for the drum, that would be nasty.
Post Posted: Mon Nov 01, 2010 5:18 am
were the shoes properly centered on the backing plate???
mine fit ok.
Post Posted: Mon Nov 01, 2010 5:20 am
and they seem to interchange ok as I used the new nt shoes on my old dif in the wt diffs with no issues
Post Posted: Mon Nov 01, 2010 5:27 am
If you, or anyone really, service a vehicle thoroughly and regularly you will know what needs replacing before it reaches its wear limit. You don't wait till your brakes are metal on metal to change the shoes do you? You want to do them while there is still material left. By using this rationale, if you find you have been supplied incorrect parts, you can refit old parts to get you mobile to enable procurement of correct items.
Hence my original statement about servicing not just fixing.
A wobbly water pump has reached its service life and should be replaced, replacing the timing belt, idler bearing and seals while you are there is standard practice.... Uni joints with ANY play in them should also be replaced.
The difference I'm getting at is scheduled versus unscheduled work..
How often do you see an ambulance broken down?
Post Posted: Mon Nov 01, 2010 5:29 am
WT shoes have a larger hole for the handbrake lever. The NT shoes can be made to fit with the right die grinder bit, but its easier to just buy the right ones.
Not sure about NT but WT are 1617's.
Post Posted: Mon Nov 01, 2010 5:59 am
All good then 8)
Lil Foot!
Post Posted: Mon Nov 01, 2010 7:39 am
just bought the car so not my fault the brakes were effed.
They were the correct shoes. so i really dunno what the issue was. All fixed with a lick on the grinder.
Users browsing this forum: Google [Bot] and 43 guests
