It is currently Mon Nov 02, 2026 5:30 pm
Post Posted: Thu Nov 04, 2010 7:29 am
my bro just brought a holden drover and when he turn his lights on (low beam) it goes from 1000rpm up to 2000rpm....has this ever happend to anyone before?? please help
!!I spend more money on oil than fuel!!
Post Posted: Thu Nov 04, 2010 7:34 am
yes its supposed too
watch the front of the carby while somebody turns the lights on, see the thingy that moves and the adjuster screw there, wind it back till its where you want it
Post Posted: Thu Nov 04, 2010 8:13 am
wow thats rare... that hardly ever works!!
Post Posted: Thu Nov 04, 2010 8:21 am
2nd this week!! where are they all coming from?
Post Posted: Thu Nov 04, 2010 8:38 am
ok thankyou ill check tomorow and ill let you guys know how we went thankyou .................... :? oh and whats so rare :? ......................
Post Posted: Thu Nov 04, 2010 8:40 am
The fact the idle up works! no one else in Australia's actually works!
GTi Turbo & A LWB Sierra.
Post Posted: Thu Nov 04, 2010 8:41 am
I never turned on the lights while the engine was running but there is an "idle up" solenoid on the front of the carby that is supposed to raise the revs when lights are turned on to compensate for the extra load on the alternator..
It is easily adjusted.
Post Posted: Thu Nov 04, 2010 9:17 am
thanks everyone..all working fine now
Vehicle: Daisy
Post Posted: Thu Dec 16, 2010 4:58 am
Bit of a dig, but turns out my one of these (idle up solenoid) works also, however it's only set to like 1000rpm or so.
Will have to keep it in mind for when I eventually fit an air compressor, assuming it needs to be switched on manually (i.e. lights) unless it works on the alternator voltage dropping or something?
Post Posted: Thu Dec 16, 2010 7:13 am
AFAIK it works on the lights and the heater fan switches...
Or the rear demister on a hardtop I think...
I want my old sig back :(
Post Posted: Thu Dec 16, 2010 7:25 am
i wired mine up on a switch on the dash... pretty cool
Vehicle: Sierra Ute '87 Sj70
Post Posted: Thu Dec 16, 2010 8:08 am
mine works perfectly fine and always has, it goes from 1000 rpm to 1500 rpm with the lights on and then you tap the brake for like 5 seconds it goes to 1800 rpm
Post Posted: Thu Dec 16, 2010 10:45 am
The idle up is controlled by a vacuum switch, which in turn is controlled by an electrical signal from the different electrical accessories, via a diode block - you can either connect additional inputs to any unused terminals on the diode block or add your own inputs by wiring in a suitable diode (1N4001 or similar).
Users browsing this forum: Google [Bot] and 89 guests
