It is currently Mon Oct 19, 2026 6:47 pm
Post Posted: Thu Apr 10, 2008 1:28 pm
I'm looking at upgrading the front struts - the stockies are topping out a bit with the coil spacers - not badly, but I don't think they are going to last long :twisted: and a bit more flex will always help too.....
Any recommendations on brand? And prices?
I have one quote of $325 delivered for a pair of Lovells Gas legend +25/30mm lift off 4WD Direct....
Post Posted: Thu Apr 10, 2008 4:16 pm
The general consensus is that OME struts are the best as they are 40mm longer, as oppossed to standard length struts with extended shafts welded on.
2002 SWB GV
Lifted and Locked
Post Posted: Thu Apr 10, 2008 9:38 pm
yep can't go past OME ones. You can also do a strut mount flip.
Post Posted: Fri Apr 11, 2008 12:24 pm
OK - I'll have a look round to get some OME ones - and I thought you couldn't do the strut top flip on the GV? Would give you the same effect as strut extenders thoughI guess - ie less compression...may be worth a look though...
Post Posted: Fri Apr 11, 2008 7:01 pm
YEah OME or Tough Dogs both around the same price.. both 2 year warrenty. If you get the Tough Dogs they supply a pair of camber pinns to re adjust that wheel angle.. OME you'll need to go get a set from say pedders and they are around $120..
:mrgreen:
Thanks,
Chris
http://www.nbs4x4club.com
Post Posted: Mon Apr 14, 2008 12:19 pm
Sweet.... I'll get a few prices today and see whats round, I've already got the camber pins - after the lift I was pretty scared by the positive camber :mrgreen:
Post Posted: Mon Apr 14, 2008 2:58 pm
Just got a few prices - OME come in at $440 for the pair - does that sound like a reasonable price? Need them for this weekend..... Cheers!
Post Posted: Mon Apr 14, 2008 3:21 pm
sounds allright but for this weekend i dought it as they dont keep GVstuff in stock :roll:
Users browsing this forum: No registered users and 341 guests
