It is currently Sun Nov 01, 2026 7:42 am
Post Posted: Sat Nov 06, 2010 6:49 am
i have a 1.3L motor and i got a new fuel pump. i put it all in new falter on it and nothing. so what i did was got a bit of hose and put it in a contaner of fuel and its not sucking any fule at all :( what could have gone wrong when i put it in??
there is a breather hose facing down from the fuel pump whats that for as there is nothing attached to it would that matter??
Post Posted: Sat Nov 06, 2010 6:57 am
Look on the ground under the eng & look for a lil push rod, they fall out if you don't know they are there....
Post Posted: Sat Nov 06, 2010 7:06 am
i had a look could i miss it i looked around the oil patch
Post Posted: Sat Nov 06, 2010 7:52 am
could be hiding in the gap of the starter, could of rolled away..
But the fuel pump will not work with out it..
Post Posted: Sat Nov 06, 2010 8:26 am
can i take it off and see if its in there?? sorry for the stupied questions i dont know much about it
Post Posted: Sat Nov 06, 2010 8:37 am
Why not, just take it off carefully, just in case it is, but I doubt it will be..
Post Posted: Sat Nov 06, 2010 8:52 am
I have done that before, quite annoying
Post Posted: Sat Nov 06, 2010 9:44 am
ok cheers guys if its not would a 1L one work??? and what size is i just cm will do?
Post Posted: Sat Nov 06, 2010 8:21 pm
No 1.0 is different setup.
The pushrod is about 55x8mm off the top of my head.
I have one here I can send if you need it.
Post Posted: Sun Nov 07, 2010 8:42 am
well pulled it out today and pulled out the rod it looked ok put it back in tourned over the motor to make sure it gos in and out and it dose
Users browsing this forum: No registered users and 384 guests
