It is currently Sun Nov 01, 2026 10:21 am
Post Posted: Mon Nov 08, 2010 9:29 am
so just while i was mucking around with my bumper and laying around under the front of my vit noticed that both my cv boots were ripped :(
just wondering how hard to replace gona go down to repco tommorrow and see what they got.
Post Posted: Mon Nov 08, 2010 9:41 am
Very greasy messy job.
I just did one.
Once I had removed the axle, I found it easier to remove the cup end, as it is clipped in with a ring around the lip, and the inner cv comes off with a circlip.
Couldn't work out how to get cv end off :oops:
If doing this way, do both inner and outer boots.
I used cable ties round boot,
to replace the original bits that were damaged.
One boot came off on last trip, so look for a a better solution, or better quality cable tie.
reco complete axles may be worth looking at, too.
Post Posted: Mon Nov 08, 2010 9:50 am
i've never had a boot fail on me but i'm interested in the price of boots from REPCO etc.... they'd want to be really cheap considering you can get a complete CV off ebay for $140, no messy grease to deal with + the old one can be kept as a spare.
http://cgi.ebay.com.au/Suzuki-Vitara-H2 ... 588ac73aca
Post Posted: Mon Nov 08, 2010 9:55 am
if you do replace the boots, stay away from the split ones that stick together. they lasted about a week on my liberty when i did them...
Think before you post to make AZ a better place :)
Post Posted: Mon Nov 08, 2010 10:03 am
Are they all the same across Vitara range.
ie it says Suzuki Vitara H20A, J20A. CV Joint Drive Shaft.
All I know is there is 22? and 26 for diff splines.
Once I have done my axle conversion, will put new ones in.
Maybe from states if dollars stays good
Post Posted: Mon Nov 08, 2010 10:09 am
the J20a & H20a are slightly longer due to the extra wheel track of the SV420 & SV620 wide track Vitara's & are 26spline on the RHS... I'm running one of the ebay specials in the LHS & it seems to be holding up fine.
Post Posted: Mon Nov 08, 2010 10:17 am
Cheers, thanx.
I just realised, splines won't matter, with 2 left hand axles ..
but length is important, so I need earlier models, for a 93 lwb
Sorry for threads hi jack Blake1191
Post Posted: Tue Nov 09, 2010 7:32 am
i had silicon boots put on mine when i got a rwc for my daily driver they were 30 each i think
Users browsing this forum: Google [Bot] and 342 guests
